cumminsbayou4x4
Front hitch is for parking trailers and launching boats...
who launches a boat going for ward? not to sound rude.
it has a solid frame and cab, bigger engine, straight front axle!
I'd run (and do) 10w-30 anyway. Add in a bottle of zinc additive, too, although your cam's probably past the point of exponential wear if the PO wasn't using any.
priced parts, you get a little
if it doesn't run right.
Uuummm, D? While you are (entirely) correct about the back story of zinc being phased out in motor oil for the environmental factors [in this case, killing cat. converters]; it's absence, just like lead in gasoline, had to be dealt with.
Like I said D, I apologize.....
Pat
Did a previous owner do a SAS? I was pretty sure that even in 1978, they were using TTB.. No?
(I'm not really a Ford guy, so I'm unsure)
While the saga of dealing with reduced amounts of lead in gas is still problematic for high performance vehicles (every OEM had to learn a great deal about metallurgy to deal with that one), the field of automotive lubricants has had the opposite problem.
To wit; Kevin Cameron, an editor for Cycle World magazine, wrote an article over 10 years ago about people who were so fanatical about getting their hands on a period perfect example of their favorite late '60's early '70's motorcycle, that they were building them from (!!!!??????!!!!) nothing but NEW,OLD-STOCK PARTS!!!!!
The problem the found themselves up against, is that when they first fired up their dream ride, they smoked and used oil like they were designed by OPEC.
Well, as you might have imagined, if you can build a period perfect motorcycle using nothing but extremely rare,priced parts, you get a little
What the OP's who spent the BIG MONEY to find out was that modern lubricants are so good that an engine assembled from all the correct factory parts is incapable of "Breaking In" using modern lubricants.
Take such an engine, fill it with the cheapest brand of motor oil that meets current standards for motor oil, and you will find what they did.
Even today, with the best standards of production, the OEM's all around the world still require a break-in period for all the vehicles they build; mostly for the engine. If the sales person claims you don't need to worry about proper break in, go find your car somewhere else (like somewhere they Honor warranties).
What they found, was that modern lubricants were so advanced and capable that the "NOS" parts couldn't achieve the required (and factory designed) partial "interference" fit needed to "break" them in. Today's lubricants are so effective that the factory perfect parts from that age couldn't make contact and start the break in process.
All Blue needs to do is keep changing his oil; keeping an eye on the dip stick (color and clarity) as well as a little common seance should keep him going.
Pat
i let my truck idle for 5 mins yesterday, backed it up and noticed a softball sized spot of oil on the snow. its coming from the rear main sealim pretty sure it wasnt leaking when i bought it..
looks like im going to have to pull the engine. might as well do the main bearings while i have it out.
i have never seen someone launch a boat driving forward. i know drivers are getting dumber but most people who have a boat are usually capable of backing a boat into the water. i would rather keep my engine as far away from the water as possible. i would hate to spend $3000+ on a new engine because you got too close to the water to launch a boat.Nearly every single person I know. It is much easier to do it that way actually. You have added visibility and more manoeuvrability.
whats the oil pressure sender look like? i am not sure that it is the rear main seal. just all around the oil pan and in between the transmission is soaked in oil
i never found an oil pressure sender. i did find a squished off tube coming out of the oil pan..
now i could see something like that coming in handy if you had to move boats or trailers all day long.
