1978 f150 flareside project
Bluethunder3320
im thinking of making a custom tailgate. the original is very rotted and warped, it'd be hard to fix. i would build almost the same exact frame, but instead of sheet metal i'd get some wooden boards like in the bed, and stain them with a nice cherry stain. ill get some pics up of what im thinking about. my friends got a whole shop where we can do just about anything. im planning to take the bed off and sandblast the frame there and maybe even take the cab off. he's got a forklift
yep, i only hear 3 shifts. so i guess it is c6. so how many speeds does the c4 have? also isn't c4 a kind of explosive, thats a terrible name for a transmission
yesterday's commute costed $20, 5 gallons. drove it again today and it was 12 gallons and 50 bucks!... something not right here! gas prices did skyrocket overnight, but i dont know how its more than twice the fuel. maybe yesterday the pump turned off before it was full?? i did the same amount of driving!
i drive 60 miles a day so 120 miles divided by 17 gallons is about... 7mpg. im gonna be driving my car to school from now on!
if i would ever put a diesel in it... powerstroke 7.3 all the way!
Bluethunder3320
i left my good drawing of the tailgate at school so heres a terrible quick sketch. let me know what you think. i only left out the latches at the top but thats easy, just a metal tab i can transfer to the new one
shaded part is the wood and the heavy lines are the welds
i can make the top part of the frame either square or round, square would be easier but round is original and matches the rest of the bed
doubter123
Madison Township, Ohio
I was only saying that since they put only c6's in the 78 and 79 Bronco's and they had the same drive train but as I said I'm not an expert I was making an educated guess.
Bluethunder3320
my friends saying the problem with the 400's main bearings is that they're really big and not enough oil gets in them. would running a thinner oil like 10w30 help? the guy has been running 10w40 quaker state
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I'd run (and do) 10w-30 anyway. Add in a bottle of zinc additive, too, although your cam's probably past the point of exponential wear if the PO wasn't using any.
Bluethunder3320
do i put the zinc additive in it every time i change the oil? and what does it do?
tried flexing on a little snow bank, didnt work at all. were getting like two feet of snow by tomorrow
also i noticed that the "ford" logo under the front bumper is actually a hitch insert, and there is a hitch under the bumper. i wonder why it's in the front? maybe the front and rear bumpers will switch
crazzywolfie
Orangeville, Ontario
that is a pretty nice truck. a lot better base to start with than you last truck. the hitch in the front can come in handy for offroading. you can get winch mounted on recivers that just slide in so you could use the winch up front or out back and then when your done you can put the winch away save so no one could steal it.
devino246
Lynchburg, VA
Yep, every time. Motor oil used to contain a fair amount of zinc (actually Zinc dithiophosphate, or ZDDP for short). ZDDP helps lubricate the flat tappet lifters in older engines, preventing wear. It was found that ZDDP damages catalytic converters, and so its use was phased out. Newer engines use roller cams and don't require the extra lubrication, but our old engines still need the stuff.
Like I said, though, if the OP didn't use oil with ZDDP, the cam will likely be trash in the future. Wear becomes exponential after the first .003XXX of wear, or something to that effect.
Bluethunder3320
so youre saying that since it hasnt been getting the zinc for who knows how long, maybe 20 years, that the parts are already worn to a point that the zinc wont help anymore? theres no cats, just a flowmaster, so thats not a problem
devino246
Lynchburg, VA
Exactly. The stock cams were crap in the first place, so it's not a huge deal.
Bluethunder3320
i wonder if someone had made that for wheelin. but there isnt one in the back. i need to look at it and see if i could get something like a reese hitch to bolt to my frame
this trucks in much better shape even though it has its issues, it has a solid frame and cab, bigger engine, straight front axle!
when a cam gets worn out it should just show less and less performance right? in that case i think im fine. its got plenty of power. i havent been beating on it, but i've definitely opened it up a couple times. and it hauls ***! breaks all four tires loose and puts a smile on my face
devino246
Lynchburg, VA
I need one too. Here you go: http://www.etrailer.com/hitch-1979_Ford_F-100,+F-150,+F-250,+F-350.htm
Basically. It won't happen quick, so you don't have a whole lot to worry about.
Bluethunder3320
since my trucks flareside it has a really small bed, it would be nice to be able to pull a trailer
