Yep, I looked at mine and I was wrong. It attaches to the arm on the drum, then the frame, but you have already figured it out.
The carb, if it's a 196 cc or a clone, pretty much the same thing, isn't adjustable except the idle screw and the throttle stop. There isn't a high speed adjustment screw.
I am not sure what you mean"wasn't adjusted to 3600 rpms. The chain should have aprox 1/2 inch of play. What do you mean the wheel won't turn if tight? If it's that tight, obviously that's too tight. Bout a half inch of play.
So you are close.
The surging of the engine may be the gov kicking in.
Keep us posted. Wish you were closer. Sounds like you need someone around to give you a hand
Good luck young man.
So you are close.
ya'll know how it goes...
