Baja heat mini bike
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
I'd recommend taking apart thhe brakes and just using some brake cleaner on then. Get em nice and clean and then just put it back together.
Hey think of tthe bright side, now you have an excuse to get the TC
kendelrk
redneck engineer
westland michigan
lol thats how im getting it, and i dont know how to take them off, and i dont want to **** anything ELSE up, but what would be good is to find some dude, thats got maybe 20 acres, all flat, that me and him could just ride on
buckeye
Aww dude. My brakes on one of mine squeek. I assume it needs new shoes. Haven't took it apart. How do you know your clutch is toast? On the rear wheel, you have one side too far back. You need to have both sides even. Easy fix. There are good you tube vids on clutch maintenence. Could just need lubed or cleaned. I have found, you always are fixing something on mini hikes. It's part of the fun.
kendelrk
redneck engineer
westland michigan
like they stop the bikes dead, i barley have to pull the lever to stop the bike, but if i want to lock the wheel, i pull it more, and i tryed to put both on equally, and then i tighten the rear wheel down, but its just whatever, so i need to figure out how to fix my breaks so they stop squeaking at me, and i need to get the torque converter, and A, because the clutch has started to slip, gets overly hot, can barley touch it without burning yourself, it looks like it has had some heat damage, and its not right, plus i want the TC, especially, and its just a matter of, getting the TC, getting my brakes fixed, adjusting the rear wheel right, and everythings good. and holdout, because blue is going to get us a video on how to do this, because im forcing him, lol, but all i need after that is to find some dude with a mini bike and some big land and ill be good, because i got in trouble with some ginger cop who thinks he could yell at not only me, but at my uncle, he then made me push it home, and followed the whole way,
B.M.800
TheBeal.
Central PA
Its their job, unfortunately for us... hope you can find someone to ride with.
Maybe you can get permission to ride someones land, theres a guy who owns quite a bit of land around here, I know theres all kinds of trails/roads/paths on it. Pretty neat place, but hes got posted signs everywhere, sued people for walkin across a field, and raised stink when our neighbors build a house by the property line...
we havnt had any trouble with the guy, and we dont want any trouble, so Im gonna ask sometime... our 20some acres gets too old after a while...
I think I ought to start a thread for my Baja Heat... hmmmm
kendelrk
redneck engineer
westland michigan
we cooperated with him tho, i see no reason for him to raise his voice quite honestly, and looking for someone hopefully, and ive been looking all around on google maps, and even if it gets old, at least you know it like the back of your hand, and hes probablly going to say no if hes going to be an *******, but yeah, do you think that torque converter will work on my baja?
B.M.800
TheBeal.
Central PA
I think that TC would work, but I cant say for sure... Ive not had the chance to fiddle with Tcs yet... I need to get some parts for mine before I can put it to use
kendelrk
redneck engineer
westland michigan
it says its genuine comet 30, and its got everything i need, ive seen you might have to grind down 2 fins on the backside, but i got an angle grinder
kendelrk
redneck engineer
westland michigan
well all that i need to do is A, get my torque converter, and B fix my brake problems, make sure my rear wheel and such are all right and ill be good,
B.M.800
TheBeal.
Central PA
yes.
your like the third person hahaha
Ok youve convinced me! As soon as I can get some pictures on the comp.
Taking the rear wheel/brakes off is pretty simple, Shouldnt be hard to get back together. Definantly clean the brake some, I would think that should help.
kendelrk
redneck engineer
westland michigan
takeing it off isint the hard part, putting it on is, lol, if i take off the bolts that hold it on, does the drum just pull out of the rim?
B.M.800
TheBeal.
Central PA
Yes, it should come right out, but there is a rock gaurd thing bolted to the brake, dont forget that.
kendelrk
redneck engineer
westland michigan
well i got the screw in, and even with the screw in, it does it, not as bad, but still, it goes then gives burst of rpm and then stops it self, like its constantly surging if i keep it full throttle
