the scrap bike #2
Homemadgokarts1221
CT
Matt my sprocket came today. We should get together and weld that up. Also want to make a sick pipe with me? Im gonna buy the tensioner tonight, then im gonna get throttle stuff. almost done! You ready to race? I say we make a track around your neighborhood.
Bluethunder3320
Yeah tonight ill look and see if i have any bent pieces like the one i found. If you want a muffler on the end, i have a tecumseh muffler but its rusted pretty bad.
Maybe we should go to welden this weekend and see if they have a old muffler.
Bluethunder3320
new pic here with new engine
Bluethunder3320
what was wrong with the other engine? looks like the end result is gonna be one sweet little ride!
didnt run right, no idle, and only on choke. i just got a new clone anyways so ill have that in for now.
but i got my parts for the tecumseh to fix it. i got an ignition coil, head gasket, and crankcase gasket.
the bike works as of now so ill make a vid soon...
Bluethunder3320
its such a beast. in the 2nd vid all that spray of dirt on the snow was from a burnout hahaha.
Bluethunder3320
good news is i went to the bike store and got cables and a twist grip hahahaha. it works great now i was putting around in the rain for over an hour. im soaked and the bike is STARTING TO RUST???
Bluethunder3320
yeah, im gonna buy some tonight!
got the brake caliper mounted, works great, exept i cant use the fancy rotor i got since it wont fit on my wheel.
throttle works too, hooked up a mountain bike twist gear shifter.
pics tonight... im gonna drive it tomorrow... and paint next weekend if i get it in time.
Right on- I was going to suggest a twist-grip- I have a few laying around ('cuz i HATE using the on my MTB's) but they look ideal for minibike throttles.
What're you using for a rotor, and is the clamping pressure decent?
Bluethunder3320
the rotor i got was supposedly $40 new... but i got it used. it is a lightweight UNEX 203mm rotor.
turns out.... it doesnt match the bolts on my wheel!! aaagghh... gonna just use the stock rotor.
as of right now the caliper is mounted, it brakes real good, and the twist grip is all set up.
i might want to paint it like lime green or something... i doubt my hardware store has POR15 but if they do im going to just get the semi-gloss black starter kit.
my other option is rustoleum paints.. my hardware store has tons of it.
so on the list....
paint
foot pegs
hook up kill switch
and i took a look at my chain tensioner... i have about an hours run time and the plastic wheel is all chewed up.
im gonna see if i have any bearings laying around that happen to fit.
Bluethunder3320
B.M. if you want a welder but dont have a lot of money or experience you should get this welder!
http://www.harborfreight.com/welding/mig-flux-welders/90-amp-flux-wire-welder-98871.html
it comes with everything you need to start a mask, wire, and the welder of course. If you can use a hot glue gun then you can use this welder! I actually have one so i would know haha
thats the welder i have. highly reccomend. works like a charm!
you cant find a better welder for the price.
I've been looking closely at the POR-15 stuff, but a bit rich for my blood.
As long as the prep is good, the Rustoleum/Tremclad option is pretty attractive. It's no POR, but it will do a good enough job for the money.
