'wittle 'wesistor (Mini Jeep)
To keep the battery cables, inside of the box, I'm going to mount the 48V 50A Circuit Breaker right onto the battery box
...in the top, left, front corner
I masked the perimeter (to highlight the "cut-out" area & help protect the outer area)
...& drilled 5/16" holes (to establish the rounded corners)
Then, cut 'er out (connecting the dots) with a cut-off wheel, in a Dremel
Then, cleaned up, the "cut-out area"
Test fit the CB
Yup, that looks like a pretty tight fit :2guns:
I used (2) pieces of 1" x 1" x 1/8" angle iron to make the battery mounting brackets
...kinda like this
The rear mount will be welded in place
...kinda like this
...& the front mount will be bolted in
...kinda like this
Safely "tucked" inside of the frame rails
...& (will be) hidden up/under the body ;)
It doesn't "hang down" much lower than, the trailing arm brackets
...so, battery box to ground clearance, shouldn't be an issue :thumbsup:
Maybe diversify the product line. :thumbsup:
Like add a "waterproof" version, made with plastic grindings :smartass:
...& for heavy duty applications, a version made with metal shavings :stir:
You are now head of R&D. Saw-Glu Mu-Glu, with a portion of milk 🥛 added for stickiness and color. Chocolate milk version available too. :cheers2:
Saw-Glu, Made for You.
I used the CAD floorboard template (to mark)
...& cut out a front section, floorboard, out of some of that 18g. steel (same as batt box) :thumbsup:
Like this :2guns:
But, after re-evaluating "the plan" I ended up eliminating the bolting flanges (cut 'em right off)
...& will transfer those duties (connecting the side panels to the floorboard) to the side panels :cheers2:
So, after re-trimming, deburring & then bending, it looks like this :)
...& then here, dry fit, on the chassis ;)
Test fit a CAD side panel on/with the steel floorboard, on the chassis :thumbsup:
Here is a pic of the front inside area
...showing how "nicely" the side panel, aligns with the floorboard :2guns:
Another view
Here are "before & after" drawings of the side panels :cheers2:
The top drawing shows the side panels without a (~1") bottom bent edge (bolting flange)
...just a bent (~1") front edge (bolting flange) & hood line
The bottom drawing includes full length, upper & lower (~1") bent edges (that can be "used as" bolting flanges)
IMO adding (~1") bends, to the top & bottom edges, should make the side panels stiffer (stronger)
...& should also, end up making them smoother too (reducing waviness) ;)
Rear section of floorboard (Mechanical Drawing)
Rear section of floorboard (CAD)
Rear section of floorboard (transferred to the steel)
Rear section of floorboard (100% cut out)
* Used the straight edges & Vice Grips as a guide to help make straight cuts
Rear section of floorboard (manually installing the front bend) (Vice Grips X 6) ;)
* Bend orientation: upwards
Rear section of floorboard (front bend, installed)
Rear section of floorboard (manually installed the mid-bend)
* Bend orientation: downwards
To mount & help support the floorboards, I added a few pieces of 1" x 1/2" x 1/8" steel channel
* The (2) middle pieces will also be used to mount & support the seats
Here's a look with the floorboard(s) "in place"
Side view
Seam looks "pretty tight" :thumbsup:
* I aligned the front piece of steel channel (under the drivers feet) with the seam, between the front & rear sections of floorboard
...so, it supports the connection of the (2) pieces
...& strengthens the "step in area" too
Here's a look at the supports under the floorboard & seating area
I've been adding a lot of steel to this chassis
...so, I figured I weigh it, just to see where we are at :thumbsup:
So, I "stood" the frame up (on the rear bumper)
...& put 'er on the scale
Looks like it comes in right at 46 lbs.
Then my wife comes around the corner :mad2:
...& asks "is that my bathroom scale?" :huh:
Um...well
...I was just checking on...:innocent:
I mean...it won't hurt anything
...it doesn't weigh as much as...:eek: o_O
Um...I mean...(smack, smack, smack) :horse:
Uh...to be continued (smack, smack, smack) :ack2:
Uh...I mean...maybe (smack, smack, smack) :surrender:
You better put it back, I told you not to take it! Mrs. Function Artist, I told him not to take it. But would he listen? Nnnnoooo! Darn kids these days!
I figured it was you :furious2:
(Remembering)
Just before she came around the corner, the phone rang
...& I heard her say "Oh REALLY! :stir:
...& then, around the corner she came :ack2:
Thanks Denny :mad2:
The moral of the story:
I learnt that I'm ONLY allowed to use her scale, when she ain't home :cornut:
Mini-Jeep
Seat(s) (diagram)
Seat(s) (bases)
Seat(s) (passenger seat dry fit)
Seat(s) (~36" seat back to pedals)
Seat(s) (~10" seat to steering wheel)
Seat(s) (~14" seat back/bottom to the steering wheel)
