'wittle 'wesistor (Mini Jeep)
Did anyone notice that (3) of the hubs (for this low speed "parade vehicle") have bearings in them? :unsure:
...& only the furthest one, to the left, has a keyway? :huh:
Front Hub w/Bearing
Rear Hub w/Bearing
Rear Hub w/keyway
You don't have keyways all the way around? I haven't followed this all the way but I thought 4WD.
No, 4 x 4
...it gets complicated & expensive real quick like ;)
I did a 4 x 4 kart a couple of years ago :cheers2:
Lunar Rover
For this vehicle, I just wanted it to look like a real Jeep (just mini) for parades & such :thumbsup:
...& for driving in parades, maneuverability at low speeds, is very important
So, I used a "live" axle for mounting the sprocket(s), brake drum & rear wheels
...but, "if" both rear wheels were "keyed" it would dramatically reduce the steering "action" at low speeds
...so, only (1) of them is "keyed" to help alleviate this issue :cornut:
So, basically it's set up as a "1 wheel peel" kart :eek:
...but, it's a secret :innocent:
...so, don't tell anyone :devil2:
I wasn't totally happy with the stamped grille(s) that I made
...so, I re-worked the jig a bit (doubled the depth)
...& re-enforced the "clamping action" (with 1/4" steel plates on both sides & 1/2 bolts with 1/2" "Hella'Nuts") :smartass:
...& inserted another steel "blank" (actually, I think they are Galvanized & not Stainless) w/1 Die on top
Stood 'er up, to actuate the "clamping bolts
...& used a torque gun to press the Die into the Mold (with the steel "blank" in between) ;)
It came out like this
I then, added another 3/4" "layer" to the Die
This how it came out
Another view
...& another
Yup, Ima likin' that a bit better :thumbsup: now that it has more structure &/or depth
...& I'm thinkin' that I can use some of the "extra material to establish some mounting "tabs" :sifone:
Next, I drilled out the holes for the light sockets :thumbsup:
The (2) hole saws on the left are for cutting out the sockets in the Dies
...& the (2) on the right are for cutting out the holes in the steel blank
Like this
Then, pressed 'em out with this
...& a 1/2" nut & bolt
...& then, they looked like this ;)
Notice the mounting flanges
...& we also have a nice wide top surface to kinda "cradle" the front of the hood :2guns:
Ta makes the Slots, I placed the "piece" on the lower "fixture"
...& put the upper Grill Slot "fixture" over top of it
Wrapped some cardboard around a pencil
...& used it to mark the cut lines, in the center if the slots
...then, cut the lines, with a cut-off wheel
Like this :thumbsup:
Minor mess up :huh:
Major mess up :ack2:
Shiz :mad2: Shiz :mad2: Shiz :mad2:
Head Lights & Marker Lights
Back to the CAD
Cur 'er down to size
Profile
CAD template dry fit in the Grille
Other side
CAD template transferred to steel
Steel inserts dry-fit in the Grille
Head Light & Marker Lights installed in the steel inserts (front & rear view)
