Which tillotson?
I like karts
Rotary Power!
Alabama
I am getting a kart mostly for riding on road and hard dirt, and I am prob. gonna get a tilly for it. I dont know whick to get tho because theres like 743674673468 models.
I want to have good bottom end tourqe and lots of power (like, able to spin wheels)
I like karts
Rotary Power!
Alabama
5hp briggs L head
Im mostly looking for bolt on upgrades.
The other things I plan to do, is put a comp cams mr. velocity torque cam with springs, some type of pipe designed for low end torque, a 3hp coil (and possibly flywheel),
and eventually a high compression head and billet rod
I really want some powerful tourque out of this thing (can you tell?), as I dont want to rev it up much until I can afford stronger internals.
btw how high can you safely rev a stock one?
ironman
I'm Back!
kentucky
Well you will hear any where from 4000 to 7000 rpms from people so i went to the local kart shop where they have alot of races using just 5 h.p. b&s motors they told me from 5000 to 6000 on a flat head you should be able to do. Now like any thing i guess it also depends on the shape your motor is in now.
oscaryu1
But remember, on a Briggs 5 horse, after around 4k RPM, oil consumption skyrockets.
kibble
I banned myself
Ummm, I don't think very many of us here have gone with anything that wasn't stock on our engines. :(
I like karts
Rotary Power!
Alabama
I think the 383 might be a bit too big.
Not sure though...hey anyone on here know any sites with the specs of different tillys?
847
big pimpin
if you are going to get a comp cam get the gp 9350 and get the valve kit for it too, if you want power it'll give it to you 4200 - 8000 rpm is the power range, but i think it builds more power around 4800-8000 i only say that because it does not have cam characteristics that a " 4200 rpm " rated cam has ( this cam is very retarded ( not stupid!! lol ) and i belive it's a high rpm power cam ) .289 lift, good duration.... make sure you grind the area where the tappets go. also get billet tappets, they are not expensive. with that cam i think you can use 383.
found a website with good prices
http://www.dowdymotorsports.com/store_camshaftsetc.htm
HL314G 314 CARB $74.00
HL348 348 CARB $80.00
HL360 360 CARB $83.00
HL368 368 CARB $72.00
HL380 380 CARB $96.00
HL383A 383 CARB $72.00
