Where did you learn to weld?
pipehack
Chicago ish
Ur not gonna weld 1/4" @ 80 or 90amps on single pass. Total BS. My hobart handler 140 is rated for 1/4 and even the chart says multipass may be needed. Ive welded thicker than 1/4" with my HH140 but metal is well prepped and multipul pass and welding very slow to insure penetration.
What wire or rod u using to weld 1/4 @ 80/90amps?
+1 Thank God I'm not the only one who knows this.
I am saying I don't agree with you on your statement fabroman, and I don't care how much experiance you have, if your gonna give an opinion and not facts, let people know that.
Exactly what statement do you disagree with?
When did I say I was offering an opinion & not fact?
You now have 4 experienced welders disagreeing with you. Experienced, formally trained tradesman don't really like it when younger, inexperienced & untrained people tel them that they're worng
exenos
Project Nut
I sure hope you aren't including me in the "Experienced" category, I'd say I'm just about average. :D
Jfive
Great falls Montana
"Anything under 200 amps is only good up to 6mm (1/4") " No mention of single pass or multipass. You can weld up to almost 3/8 with 200 amps.
Br@ndoM@n
Dude with a gokart, a MIG
New Mexico (Not Dirty Poor Mexico, NO HABLA ESPANO
U easily can weld 1/4" under 200amps. hell 250 machines are rated @ 1/2". What I and others are saying is that u cant weld 1/4" with 80-90 amps and get enough penetration. Lets face it u nor I cant truly know if ur getting penetration @ any set amps unless u have it xrayed or cut it a sample peice to see for sure. I do some practise runs of scrap peices before I weld something structural then beat on it with a "BFH" and if the weld fails then I adjust my settings and/or travel speed/technique and then try again. once I get test out a test peice that doesnt fail I do my actual welds using those settings/speed/technique.
Maybe with a stick but you'd be pushing it with MIG. I sure wouldn't be betting my a$$ on those welds being strong enough
Jfive
Great falls Montana
I had the 90amp harbor freight welder before, and used it to weld up to 1/4". I did prep the metal to do this in multipass though. You just cut the metal at a slight angle and flip one piece so that you have a V to weld into, and tack weld the back out a bit, so that it will remain flat when you fill in the other side of the V. When your done you will have a strong weld. It may take a little time, but you should be able to get the job done, if you know what your doing. This was the way I was taught in school, as the teacher knew that guys will not be able to afford a super nice 220 welder, and may use a 110 to do some repairs, or build something at some point. When I get home from work in a few weeks, I will make a point to do a weld, and I will cut it and polish it and etch it to see what I can do.
eatmydust
Butthole of Cali...JK Modesto Ca
Sup guys, I learned to MIG & TIG at my last job about 3 years ago, I knew nothing going in , worked my way up to learning tube bending and to tig stainless and purge welding with foot activated positioners , Even learned how to program the robot welder. Jobs before were Roofer , then call center , my resume is funny.
skanga71
I'm new here and been welding professionally for nearly 20 years. I reckon myself a very good welder, but the truth is that I am always learning something new. For those of you looking to learn good techniques or something new, I would check out weldingtipsandtricks.com
Dang good site for info:thumbsup:
Good to know, thanks guys :thumbsup:
stacy
Self taught, mig only. Cut my teeth on this old beater.
mike.
NE Ohio
Taught myself. Not too good but I have some very very bad equipment so I cannot tell you what I could do with better machines. I can never get good solid welds. I always have to go back and fill gaps.
Most of the time, unless your equipment is reeealy bad, it's not the equipment, it's the operator.:roflol:
What are you having problems with?
mike.
NE Ohio
Well I think it might be the equipment. I used a Miller on my car that had all the adjustments and fancy stuff and I did decent. Now I have some off brand flux core wire fed welder that just spatters all over, the wire hops around and the speed adjustment is very temperamental. I prep the surfaces 110% before I start but that never makes a difference. My welds have gaps mostly. My grandpa's arc welder doesn't even give me as many issues and I think that thing is a hundred years old.
Pop quiz- Are you using the cheap***t wire that came with the machine? I am pretty competent behind a gun, and I have had problems with low-buck flux wire...
