fowler
Ha true
Nice Tv cabinet Fabroman. Is there nothing you can't do?
I do not know and I know that it is "easy" (as some describe it), but is there such a thing as a welding service ? I am sure there is a workshop out there that would be willing to weld, but does anybody know if there is such a thing as welding services ?
I half taught myself......I havent taught the other half yet
I just cant do fillet welds (theyre the 90 degree ones right?) and odd spot welds i suck at
My butt welds are generally very nice though lol
Anything under 200 amps is only good up to 6mm (1/4")
The same principles apply with fillets though; work in small circles or zig zag as you move along.
You don't need 200 amps for 1/4" :wink2: I do 1/4'' as low as 80amps, and get good penetration. 125 is really about as high as you want to go with 1/4".
That with a mig or arc? I cant get good penetration with my 90 amp mig on 3/16 no mater what I do but I can get good penetration with my arc on 1/4 using 6011 rods at 90 amp.
Also, finish reading the thread before you post, you'll find that fabromans post is proved right because me is talking about a mig with gas
sorry to say anything on this subject but arc welding is actually three different types of welding, (stick mig and tig) aka (smaw gmaw and gtaw) aka (shielded metal ARC welding, gas metal ARC welding, and gas tungsten ARC welding)
don't mean to be a nag![]()
I knew you what you meant by arc. I always call stick arc. I was refering to stick, but you should be able to weld 3/16 with flux core wire at 90 amps. I imagine thats what high on a 90 amp harbor freight welder does. Realize that by using flux core wire your able to weld thicker material. Gas might make it easier to reduce splatter, but when you see the ratings of machines there best is with flux. You might want to try gaping the material a little bit, and don't move the torch in circles, or side to side. Also you still don't need 200 amps to weld 1/4" steel even with mig with gas. A 110v mig can do 1/4'' and they don't get anywhere near 200 amps. You should research what your saying before you try to correct someone.
I admit I don't have 20 years experiance
I am not saying you don't know what your doing or anything, just don't want people to think they can't build stuff with the smaller welders that they have. My comment wasn't for you directly as it was exenos that said I was mis imforming
Ur not gonna weld 1/4" @ 80 or 90amps on single pass. Total BS. My hobart handler 140 is rated for 1/4 and even the chart says multipass may be needed. Ive welded thicker than 1/4" with my HH140 but metal is well prepped and multipul pass and welding very slow to insure penetration.
What wire or rod u using to weld 1/4 @ 80/90amps?
