Time to start on the frame
The solution was in the cards; it had to be based on two rectangle section frame rails like a real hot rod. So I went and got some 25x50x3mm (1x2’’, 1/8’’ wall thickness). Cut the 2 rails a little longer than needed:
I wanted to contour the frame to meet a few criterias:
- Wide in the back to put the axle bearings close to the rear wheels
- Frame rails should follow the edge of the ‘’body’’ i.e. wheelbarrow tray
- Narrow in the front to get the split wishbones swung in and away from the front wheels. And to bring forward the looks of the I beam axle.
So I started cutting up my perfectly good rails!
And finished off with a mock up:
Rails are too long front and back, will cut to length and get some crossmembers in there as the next step
