What type of axle should I have?
ultralight01
Senior Yet Young Member
Hood River, OR, In a galaxy far far away
Yes! !!! that is a live axle setup...(maybe a Carter Bros?)
The "Heavy" kart I worked on for OrangeKrate's mini series was exactly like that. Bearings press into the flanged ends of that tube,a keyed alxe with threaded ends holds keyed rims in place with a double hub on the drive side.
We need a measurement of that tube...plus the ID for the bearings and we can help advise you!
Oooooh!!!! :idea2:
Poboy kartman
Senior Moments Member
White Settlement Texas
Sooo...just to get started: a good rule of thumb would be 6" on each side outside the tube....so...42" however..I really think you need 48"....(offset to drive side) Ideally, only keyed on the ends and threaded. Yeah 3/4" would be a good axle....(it might have even been 5/8" originally) ....and basically...because of the proximity of the bearing to the sprocket and bearings to wheels...actually isn't bad. Typically, live axle hangars are further away from the wheels.
Sooo..That's a start...I could search for the parts, but I can't give you a link, and there are guys that are better than me at that....
You didn't answer my question as to how tall a tire you want in the back. 6" keyed hubs shouldn't be too hard to find....but it's gotta start with the axle....ideally...we can find a 3/4 and 5/8" .....then bearings......then hubs, wheels, sprocket, brakes and clutch.
dirtmcgirtld
Florida
Seems like the easiest tire to find is the 145/70-6 so I'll probably stick with that.
dirtmcgirtld
Florida
Also I think I'd rather avoid the jackshaft and save the TC for down the road if possible.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I agree for simplicity and budget sake. But...
The design of that kart kinda requires it. ( I think)
With the axle in the Tube, there is no way to out a Sprocket on the Axle lined up with the motor clutch sprocket.
Thats why I said I do not know too much about your Kart style.
Can you fabricate stuff, Weld etc?.
I can... So if it were mine I would cut that axle tube off and the Jackshaft mount and welds in bearing hangars and a more typical live axle setup.
Poboy kartman
Annnnnnddddd....by the time you get through hacking up a perfectly good system already set up for a torque converter....you'll have just as much money in it as a jackshaft, but a much crappier set-up!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I realized something else too. since yesterday. You would need 3/4 hubs and new rear wheels for the current setup and 3/4" axle. $$$$
I just donno bout this one.
Poboy kartman
Any way he goes....there's going to be money involved. He's gotta get wheels, some type of axle system and brakes.
To me it just seems like a jackshaft is going to be the easiest way to go....but for a little less money, and a LOT more fab...he could convert it to a one wheeled wonder.
dirtmcgirtld
Florida
So I couldn't weld a motor mount in place of the jackshaft mount and just have the sprocket to the outside of the frame and run a clutch and chain straight to the axle?
dirtmcgirtld
Florida
While I don't want to spend a fortune on this thing, I'm not SO worried about cost only because this will be a pretty drawn out project. My son is only four so he can't even drive it yet.
I have the time to space out buying parts.
dirtmcgirtld
Florida
Found some pictures of the same style axle by searching "carter brothers live axle."
