Jblankster
A a a poke a bear with me I'm using voice activation software to type this because I'm lazy.
Okay so here's my idea I currently have the setup on my minibiek, which is a jack shaft set up to the gear down below what ever.
So as you see there that is hell is currently set up. Soul what I'm thinking about doing it is either getting a big bully clutch and in gearing a bit higher to make more speed, which would be the easiest way to do it, and possibly the cheapest.
And other thing I can do is get a comic torque converter and taking off that jack shaft and setting up that way.
But another option is to completely replace the motor with a dirt bike motor with five speed Manual transmission and setting up with that. Or putting a bigger briggs engine on there, and putting a torque converter or clutch etc.
then exhaust opinion/help
heres my current exhaust set up
So I want to take off my in many bikes muffler, and either had a piece from the engine and continue the exhaust that is on there currently, or I saw someone hope up a a motorcycle exhaust (like one of those real nice ones, i have pics some ware ill try n find em), which would be muffled, and even sounded pretty good.
What you must think I should do about that?
Looking forward to your replies
-Jblankster
-Jblankster
