what is good
BradenM
Etre Et Durer.
In a big jar of Nutella, nom nom nom
I think perhaps having a geared ATV like-starter would perhaps work in conjunction with a jackshaft or 2, but It would be unnecessarily complicated. If you wanted to prove it could be done, go ahead, but it you just want to turn the key and go, the 6.5 electric start is what you need.
Kenny_McCormic
Kartless....
Michigan Troll
Would require a special block. Problem with the 6.5s is you gotta run em box stock, no modding cause your stuck with that flywheel. Unless ARC will make a geared flywheel for you.
ZnsaneRyder
Crazy Guy on a Bicycle
FL
jr dragster T
Cold place
With all due respect I do belive he wanted to make his readily avaible 5 hp briggs electric start and not pay $205 for a clone. Now I know my Tecumsea 5 hp has 2 mounting screws on the block and a geared flywheel. I think it was a 120 VAC starter though.
BradenM
Etre Et Durer.
Easiest way to mod a motor without the geared flywheel is probably having a geared jackshaft, both with a clutch, and with your electric motor attached. This is easier then lengthening a stock output shaft.
(Off Topic, but the Recoil starter on a Victa is actually geared into the flywheel, via flywheel teeth...electric project?)
robin
in a house
get a sprocket press a one way bearing onto it then slip that over your engine shaft then connect this sprocket to suitable electric motor then you also have the problem of you batter going dead
imo it would be cheeper to get an electric start engine in the first place and i am sure it would work much better
ZnsaneRyder
FL
Read the first post again Tyler:
what is a cheap eletric start engine for a gokart or how can i make a 5hp briggs eletric start
For the hassle and $$$ of modifying and adding a starter to the 5HP B&S, the Electric Start 6.5HP clone would do the job better. $205 is cheap for a well equipped 6.5. Especially for a karting newbie in this case.
However, if someone wants to fill the original poster in the proper way to mod his briggs, I'm all for it. It was just the egotistical comments of what a REAL man means, which is nothing but a bunch of society nonsense, and was not helping at all with the post.
ZnsaneRyder
FL
I agree completely! If he has the room to add a jackshaft, that would be great.
ZnsaneRyder
FL
Such language!!!
I was being easy on the language by only saying hell. I am a grown 26 year old adult, and say what I want to say, but I was keeping it on the easy side because there's obviously kids here. LOL
This is a DIY karting forum, and we need to be open-minded and offer help more to our members. I feel it necessary to be expressive to prove a point.
kibble
I banned myself
I wouldn't bother trying to make the 5HP an electric start (just opinion), if you have the money, and just get the clone with it built in.
And just for the LOLz, Real men are members called Kibble... :roflol:
r_chez_08
Should be in the shop...
Cornwall, UK
if u already have the briggs, keep it as it is. if not buy a honda clone. best engine for the price.
thgrahamjr
Love To Build!
Clewiston Florida
G racer basicly what everyone is trying to tell you is that there is no cheap way to convert the 5hp engine you have to an electric start. I know you already have that engine but with the money you will spend trying to convert that engine you could buy a Honda clone with E-start for about the same amount.
Kenny_McCormic
Kartless....
Michigan Troll
E start is nothing but trouble, its another(rather delicate) thing to break on a machine that likes to break a lot. Go karts are rather high maintenance things. Pushing a button is cool but is it worth all the batteries you will rattle apart?
