what is good
BradenM
Etre Et Durer.
In a big jar of Nutella, nom nom nom
To the best of my knowledge you can't bolt an electric start onto a B&S 5hp, however, you could do it Ghetto style; electric motor to the flywheel instead of the recoil housing, but this I do not recommend.
g racer
go kart builder
jacksonville FL duval
how can i make it electric start then i never worry about the waight on the cart it is just for the yard im not raceing it it is just for play i just hate geting up and pull pull pull until it cranks i just want to to push the button or turn the key and it starts plz im just a house mecanic
ed1380
Banned
ATL, GA
...not to mention the extra weight.
Real men use rope/cup starters. Cheap, light, and cannot fail...ever.
i had a tec with the starter cup. i hated it. poorly designed. my fav so far would have to be the briggs recoil ball clutch thing
Russ2251
AZUSA:Powered by LAWN-BOY
Actually real men use kick starters.
How would you know???:roflol:
Briggs recoils are good but do have one drawback. On occasion I've had the need to turn crankshaft in clockwise direction. Can't be done with recoil in place. It's a minor thing, but still bugs me. As far as I know, Briggs owns the rights to this system and therefore is/was the only manufacturer to use it.
Kenny_McCormic
Kartless....
Michigan Troll
My dad has an old tecumpseh kick starter from the 50s, real neat, he has a few cast iron block 5hp tecs from the same time period that the kicker will fit (2 loose ones and a tiller model mounted on a tiller that does the garden every once in a while). Old iron FTW.
I dont like the briggs clutches, enigne backfires? Broken rope. Let it sit for a long time? Clutch seizes too shaft. I prefer the hand wound rope starters over everyhting else, only part that can break(rope+handle) can be made in less than 10 minutes.
BradenM
Etre Et Durer.
Tune your engine better and it will start better. If you really really really want to make it electric start, I would suggest you post some pictures of the motor with the flywheel housing removed.
Real men kick start motors with their teeth.
Russ2251
Don't know that it can be done. Might require specific block that will accept a self starter. May just need mouting hardware. Someone else may know.
Flywheel will have to changed, circuitry added, as well as a place for mounting battery. Do you want a charging system as well? Add an alternator/regulator.
