bighead
Why was the motor tore apart?
looks pretty good so far.
maybe support the tranny area a bit more? why out the engine so far away from the tranny? good to see your using a clamp on the drill press now. looks like a nice place to work, heated(?), and you don't have to move the tools around.
do those wheels have bearings or bushings? also it is stronger if you don't have the ends of the tubes open.
You could try that. You could also try adding one to the input shaft, which may require extension. You could add a brake at each wheel.
The problem with braking an open differential at the pinion is that it can exhibit some very odd behavior in varying traction conditions. On the tractor at low speed and weak brakes, not much is noticeable. At higher speeds, and with enough clamping force to lock 'em up on loose surfaces, you can actually end up with one wheel still rolling forward, while the other one actually spins backward! Freaky as it is, I had this happen to me a couple times while doing the shakedown runs on my kids' kart, which uses a differential from an old lawn tractor. It was really weird, braking hard and throwing gravel forward! This occurred on loose gravel, locking the brakes hard at full bore.
