Van Kart
FreeRunner15
i like how it looks like its ready to be drag raced with the big slicks on the back.
Atlanta, GA
**** I love what you've built here. I really am impressed. The Kruger thing was a joke, ever watch Seinfeld?
FreeRunner15
One thing for certain is this Vankart has a high COG (I knew it would from the start). After a bunch of taunting from my buddies and several attempts to bust out a 180* slide, I nearly nailed a few but this one was caught on video.
https://www.youtube.com/watch?v=Pph2Bt0yiYs
---------- Post added at 10:17 AM ---------- Previous post was at 10:09 AM ----------
when you started to flip i was like "whooaaaAhh." i thought it was funny the other guy said the same thing.
bigair49
Southern Ontario Canada
Ah man that went over my head ..
Some nice clean steel after the wheelabrating..
---------- Post added at 08:03 PM ---------- Previous post was at 07:51 PM ----------
ya man it was a little scary should have had my helmet on but it was fun!!
Poboy kartman
Senior Moments Member
White Settlement Texas
That's clean...but despite..the smartalecks around here "That can read!" Some of us just wanna see pics...because we can't...What is this this "FreeRunner abrasive device' of which you speak ?
bigair49
Well this thing has four monster wheels that throw steel shot and sand at opposing angles wile the piece is transported down the rollers and out the other end shiny and ready for finishing.
bigair49
Ya it makes blasting stuff so easy. You can't use it for thinner materials and delicate stuff it will not come out the other side in very good shape if at all.
bigair49
Ok so with the frame all cleaned up and the welds touched up, I got some Epoxy Primer on it to seal in the freshness of the blasted steel.
I got some goody's for the engine today!! Ill fill you in tomorrow!
bigair49
Close... but I will still run The CAT PISS in this one as the compression will be higher but is still low enough that it will not require high test petrol, good old 89-94 should work fine. I did however put together a nice little package, Race head with S20 cam with larger valves 22/25mm for low end torque, High volume oil pump, 54 mm cylinder and domed piston and a high torque starter to top it off. I might need a larger carb so I ordered a Kitaco 24mm carb just in case.
This old girl was pretty dirty in the bottom end :ack2: the oil filter was full of crap but no metal so I'll clean things up and inspect the gears.I might even lighten up the flywheel..............
Cheers and have fun..
Poboy kartman
Oh WAIT! I think he's speaking GREEK!:lolgoku:
Make sure to clean the centrifugal oil filter on the clutch basket. A lot of people don't know about those and never do it that's why those engines die. :thumbsup:
