Torsk (Backbone Chassis) Kart
A little artwork while I was thinkin' :idea2:
I first contemplated using 4' round tube but, it seems like it would be easier to attach to flat surfaces
IDK it also just seems like round tube would twist more :ack2:
Then, I was leaning toward 4" x 4" x 1/8" square tube (~6.5 lbs. per ft.)
But, the 12V 12AH batteries, being 4" wide, would not fit inside a 4" square tube (~3 3/4" ID.)
So, now I'm thinkin' 2" x 6" x 1/8" rectangular tube
...it's also ~6.5 lbs. per ft. (same as 4" x 4" square tube)
...but, I can cut out 4" (for the batteries) of the 6" wide tube & still have ~1" of steel wrap around to help maintain the "rigidity" of the backbone :thumbsup:
Front Axle, could be made of 1" x 3" x 1/8" steel, ~18" wide
...proportionally reduced from the backbone dimensions (2" x 6" to 1" x 3")
I am thinkin' of leaving the axle as (1) piece, cutting 1" x 3" slots on each side of the backbone & running it right thru :2guns:
...the left side axle stub would be 6", the backbone is 6" wide & the right side axle stub is 6" also (kinda of a 1:1:1 ratio)
Rear Axle Housing, could be made of 2" x 1/8" round tube ~14" wide
...it could cap off the rear end of the backbone
I am thinkin' of running the 1" axle thru it (like a true backbone chassis) & just having the bearings mounted right on the ends
...the left side axle housing would be 4", the backbone is (of course) 6" wide & the right side axle housing would be 4"
...the sprocket could be mounted between the bearing & the wheel, on one side
...& the brake rotor/drum on the other side :cheers2:
May do a mono-shock type suspension in the back
Still thinkin' on that one :cornut:
Got my order from BMI Karts this morning (just ordered Thursday that was quick) :thumbsup:
I ordered some of the stuff that I usually don't or can't make myself
I asked about the DIYGK discount but, they said that they don't offer us a discount. (we need to work on that)
They still have the best deals, so...
ya, here's what I got :cheers2:
(1) Front spindle kit - (1) left & (1) right 4 1/2" x 5/8" (don't trust my weldin' skills that much)
(1) Rear Axle Bearing kit - for 1" axle (lighter than pillow blocks)
(1) Rear Axle - 1" x 32" with 1/4" full length key way (should be beefy enough for this concept)
(2) Lock Nuts - for 1" axle
(1) 12" of Key way stock - 1/4" x 1/4" (I should be able to cut all of the keys I need for this project) (1) for each rear wheel, (1) for the sprocket & (1) for the brake rotor/drum
(2) Rear Rims - 6" x 5" with a 1" bore & 1/4" key way
I also picked up (4) of these kool 10.5 x 4.5 x 6" Unilli "racing slicks" (they were on sale for ~$20.00 ea.)
Couldn't pass em' up :2guns:
But, wow they are low rider's/ground huggers
What's up with these directional arrows?
...If all arrows are pointing forward, the kool yellow letters won't be facing outward on one side :ack2:
Picked some metal today :thumbsup:
Some 2" x 6" x 1/8" (11g.) rectangular tube for the backbone
Some 1 1/2" x 3" x 1/8" (11g.) rectangular tube for the front axle
I wanted 1" x 3" rec. tube for the front axle but, they were out of it
Should be able to make it work
I am thinkin' a 6" nose cone & 6" axle stubs, on each side will look kool & balanced :2guns:
Rounded up some 2" round pipe with a 1/8" wall for the rear axle housing
Cut off a crusty end & then a 14" piece
Marked the center & then 3" each way
Put the axle thru with the rims roughly in place
Lined it up with a 2" x 6" just to see how everything looks in "real" life
Looks pretty good to me :thumbsup:
Plenty of room
...for the bearing & sprocket on one side of the axle & the bearing & brake on the other
...& to mount the motor on one side of the axle housing & the brake hardware on the other :cheers2:
Gotta weld on a flange or plate to mount the bearings to each side
Rear Axle Housing Bearing Mounts
Plan A.)
4" circle, 1/8" flat steel, with ~1 1/2" hole in the middle
welded on each end of the rear axle housing
with some braces added for support
Plan B.)
2" x 2" angle steel ~4", with a ~1 1/2" hole in the middle
would square up on the end of the axle housing nicely
& double as a motor mount or brake mounting bracket :thumbsup:
Lets lay things out to see where were at
...& start to lock down some dimensions :thumbsup:
Backbone - 2" x 6" x 48" long rectangular tube
Front Axle Housing - 1 1/2" x 3" rectangular tube
Rear Axle Housing 2" x 14" round tube
Starting at the front
6" for nose cone
3" for front axle housing
6" for each of the (4) batteries (~24")
which leaves ~17" to the rear axle housing
I think we can squeeze a seat & a motor in there :cheers2:
Not enough room to land a 747
...but, should work :thumbsup:
Next, where/how to mount the motor
...that should give us more info on how/where we are gonna mount the bearings
Well, lets dry fit
...the axle in the housing
...with the bearings on each side
...& the sprocket
...& the rims
It looks like to line up the motor sprocket with the axle sprocket & to clear the sprocket (have adequate distance between the sprockets)
The motor mount needs to be ~4 1/2" out from the backbone
...& ~6" forward from the axle housing
Atlanta, GA
Plan A.)
Plan B.)
Plan B is a winner
A few more ideas :thumbsup:
I made up a couple of "A" frames
...just to see how it would look
NOT feelin' it :ack2:
Still like the original plan :2guns:
Plan A.)
Plan B.)
Came up with a few more ideas :thumbsup:
Plan C.)
4" x ~12" triangle, gusset plates to strengthen the axle housing to backbone connection
& mount the motor or brake on to
(a lot of separate parts to fabricate & weld together & still mostly just (2D) two dimensional)
Plan D.)
2 1/2" x 1/8" x ~24" custom bent steel side plates
with a 5" x 6" motor mount welded on top
(only (2) "simple" parts for each side)
I'm likin' Plan D.
...simple & lightweight :cheers2:
...more (3D) 3 dimensional :cool:
...with some triangulation thrown in :2guns:
The rear axle bearing brackets are ~3" x ~4"
I thought about using 3" x 1/8" steel but, the backbone is only 2"
so, I am gonna split the difference & go with 2 1/2" x 1/8" steel :thumbsup:
The top & bottom edges will hang over just a bit
but, it should be kool :cool:
What if you use a tubular rear axle carrier with press fit bearings instead of flanges on the ends?
Doesn't sound very DIY
Always open to new ideas :thumbsup:
but, need more info
Pic's, drawings, links ...something :cheers2:
---------- Post added at 08:42 AM ---------- Previous post was at 08:27 AM ----------
I have a pretty good idea on how everything will be layed out
& how the front axle will be set up
& the rear axle too :thumbsup:
Next, I want to get the battery "tray" cut out
& then see how rigid the backbone still is
Also, thinkin' about doin (2) 12" x 4" battery cut outs
with a 2" space or bar left in between the front (2) batteries & the rear (2) batteries
...instead of (1) big 24" x 4" cut out
This should help maintain the overall rigidity better
...& the 2" bar should also act as a "frame fuse" or indicator
If the backbone does any extra-ordinary flexing, the 2" bar should show some warpage :2guns:
To cut out the battery box opening
...I could use my cut-off tool but, would have to rig up a cutting guide, (8) times :ack2:
I think I'll (try to) use a jig-saw for this project
...mostly by eye but, it does have an attachable guide that may be helpful :thumbsup:
Starting at the front axle, I drew out where the front (2) batteries will sit. Then, I left a 2" space (frame fuse) & drew out where the (2) rear batteries will sit.
I center punched drilling spots in all (4) corners of where the front batteries will sit & drilled 1/8" pilot holes then 3/16" holes & then finally 5/16" holes to have a place for the jig-saw blade to start from.
The cutting for the first box went really well for the (2) long (12") cuts but, when I cut across from one cut to the other
...@ the very end there was a pop & the metal raised up ~1"
scared the crap out of me :smiley_omg:
I was just concentratin' & cuttin' along & suddenly the metal came alive
