torque converter
xxmiaja
xxmiaja
atlanta
Ok guys I'm new here and I have a question.i have a 11 hp engine with 1" shaft.im using a 40 series torque converter,her is my situation.with what way I had to move mounting plate over for this engine to fit Now in order to line up driver and driven the driver clutch on the engine is not completely flush on the engine I had to put a spacer on the Shaft first to move the driver over a little in order for everything to line up will this hurt anything
firemanjim
Just kartin' around....
Houston Texas
Post pics for the most accurate answer. Sounds like it will be good to go, but you never know what some yahoo has done, and explanations can be sometimes misleading....
xxmiaja
xxmiaja
atlanta
Ok thanks for your reply guys I will take pics today when I get home.project almost done just need a jack shaft.i ordered a 10" jack shaft this weekend
xxmiaja
xxmiaja
atlanta
ok i am inserting pics of the torque converter sitting away from engine out on shaft..is this safe also since this is a 40 series do i need support om the left side of driven as well or will this work
firemanjim
Houston Texas
Just make a spacer the right length out of tube or pipe. (not a STACK of washers) Get a longer bolt to hold it all on and your set! Nice looking TC.....
xxmiaja
xxmiaja
atlanta
im sorry is the support on my driven on the right side coming from my engine plate enought support for all the tourque
mysteryboy28
Lansing, MI
is the driven clutch facing the right way? if i'm not mistaken, the 40 series driven faces the opposite way. i know it does on my kart...
also, please use the "edit" button, rather than adding another post immediately following your own posts. :)
xxmiaja
xxmiaja
atlanta
I though it did not matter which way the driven pull was mounted.i have seen both in both directions..would it not do the same either way
firemanjim
Houston Texas
Yeah, I think it does matter to certain extent. There is a wound up spring in there that I think is only gonna work properly with it facing the other way.....
I'm no TC expert, so I didn't catch it being on backwards. Oops....
xxmiaja
xxmiaja
atlanta
If that is the case then I have a problem.once the rpm get high it will open up and hit the sprocket.and I could bring it out more but I would have to bring out the driver as well and it will be sitting to far out on the Shaft
88nightrider
Norway, Sandnessjoen
Are you talking about the pulley sitting on your jackshaft?
I think they are only talking about you having to flip the "driven" unit (the one that sits in the engine).
Might have to change some other things to make it all align tho.
xxmiaja
xxmiaja
atlanta
No the driver is on the engine the driven is on the jackshaft.i have done some research I can use the driven the way it sits but I must order a new spring that is reversed wound for it to work like I have it in the picture
88nightrider
Sorry about that. I am by no way an expert in torque converters, so I'm sorry about mixing the terminology of some of the parts :mad2::oops:
Then there should not be a problem with your installation :thumbsup:
KartFab
Dallas, TX
Before you go ordering springs, can you relocate the axle sprocket and Jackshaft sprocket to the other side of the engine to make more room?
xxmiaja
xxmiaja
atlanta
i thought about that tonight relocating the sprocket to the other side but threr is no key groove on that side
