qtband
You mentioned using a spacer on the driver. If you remove it and slide the driver all the way on the crankshaft, then remove the jackshaft sprocket and relocate it to the other side, will the driven then have enough room to open? If so, you can slide the axle sprocket over and just cut a keyway where you need it with a dremel or other small grinder.
