Torque Converter Problem
Nma__1
Hi,
I currently have a go kart that i build my self and it has a couple issues. The main one being the clutch to axle system. I have a predator 212cc with a jet'd carb and an exaust, but the problem is that i burn through clutches within a week of good riding. The teeth of the clutch actually get sheered off, and im not sure why this is happening. Anyone have any ideas?
---------- Post added at 07:03 PM ---------- Previous post was at 07:02 PM ----------
I was thinking about getting a torque converter, but the space between my drive shaft and my axle is not enough to fit anything more than just a clutch.
Jrgunn5150
Rudderless
Are you certain that the clutch is aligned, and more importantly, the correct chain size is being used?
KartFab
Dallas, TX
Premature sprocket wear:
1) wear on one side of sprocket is a sign of misalignment
2) saw like teeth, where sprocket teeth valleys get deeper is a sign on chain that is too tight
3) rounded ridges is a sign of the chain becoming too lose, usually happens if chain slips and skips over the teeth ridges
Also like jrgunn pointed out. Chain size is a big deal.
Take your chain and look at it, can you move it freely or does it get kinks in it? Are the rollers round or do they have flat spots in them? Any Knicks/burrs?
Proper chain tension is also important. You don't want it too tight or too lose.
Also, based on what you have said about the engine and clutch, you may just be putting out more HP than the clutch can handle.
Here are a few questions:
1) tooth count on clutch
2) tooth count on axle sprocket
3) tire diameter
Ideally for stop and go driving a standard yard kart should be geared for about 25 mph at 3600 rpm.
Another thing. The torque converter can be pointed straight up. It looks weird, but that orientation does work with limited space.
Nma__1
1. 12 teeth
2. 60 teeth
3. 18 inches
I was unsure about how to mount the torque converter with limited space, but that gives me a good idea.
Also i have made sure to use the correct chain size 35
---------- Post added at 10:14 PM ---------- Previous post was at 10:07 PM ----------
how would i mount the torque converter vertically?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Wow. that ratio and tires is NO good for a clutch.
Typically we see and recomend
12
72
and no more than 15.
You can run 18s but you need different gears.
Like 80 and 10.
Or a torque conv. or Jackshaft
I'm confused do you have a centrifugal clutch or a tav system because from what I'm reading everyone is talking about both.
Nma__1
Could someone give me a recommendation for a torque converter system for a go kart running with a predator 212cc. Also the space between the drive shaft of the engine and the sprocket on the axle is small so how would i install it?
Atlanta, GA
Repeating what others have said, if you could post a picture or 2 it would be very helpful.
Look on eBay for torque converter kits with a 3/4" bore. There are plenty to choose from.
leesiel
Yardcart 196
Savannah G.A.
[/QUOTE]
Another thing. The torque converter can be pointed straight up. It looks weird, but that orientation does work with limited space.[/QUOTE]
So would a t.c. be adaptable (easily,somewhat) to a dead axle?
Poboy kartman
Senior Moments Member
White Settlement Texas
So would a t.c. be adaptable (easily,somewhat) to a dead axle?[/QUOTE]
First off; why not just regear???? (Even with a TC...you may need to anyway! )
Second: WHERE ARE THE PICS?
Third: Why do you think you need 2 threads for 1 question?
Nma__1
1. What do you mean by re-gear?
2. I dont have a camera available to me although i will soon
3. I asked two different questions, so i thought i would make a different thread, i was under the impression that different questions go on different threads.
He means that the rear axle might need to be potentially a 72 tooth sprocket instead of 60..... hence the word re-gear.
Not if the questions are about the same cart and related :thumbsup:
FreeRunner15
When i made the clutch to TAV conversion on my dead axle kart the sprockets wouldn't line up at all ...
..so i redesigned my kart.
You could drill an area where you want the engine to be mounted a bit more on the left side of the engine mount.
