BrownStainRacing
- Messages
- 1,367
- Reaction score
- 1,486
I've taken a bunch of these NIB pred 212's apart for checking clearances.I’m not sure what kind of ring gap this engine has from the factory…
If I go with 0.0055” of gap per inch of bore…
2.835” x 0.0055 = 0.016”
According to this chart for less than 15lbs of boost a 70mm bore needs 0.016” ring gap on first and second ring.
Ring end gaps are all over the place, .010"-.022". Some have the 2nd ring tighter the the top ring.
Same with piston to cylinder. There's never 2 the same.
It might be best for you to pull it apart and check.
That way you can clean up the crank (smooth out the rough jagged edges), shim the crank and cam. Looks like you gonna need a "bullet proof " bottom end.
