The centerline is ground into the cam. No you can’t change that. But you can advance or retard them.
Let’s see if the rings fit with about 0.016” gap now.
Im afraid I removed too much material and the gap that was 0.013” will now be 0.020”
And what do y’all think about carb size?
My plan was to use a 30mm (which I have) with the blower, but had a 21 or 22mm on this engine when running NA. I probably have a 24mm around here somewhere. They are all basically the same carb with different sized Venturis bored though.
While looking at the carb options and seeing the methanol ones, I remembered to start considering compression ratio.
After milling 0.035” off the head for an 18.4cc chamber and using the +0.020” connecting rod, the CR with a 0.040” gasket will still be around 10.4 : 1
Since the pulleys might deliver 11 psi of boost and the intake temps will be hot, I’m thinking alcohol is the answer.
Well PB blaster, a torch, a few pullers with clamps with a pipe wrench… I don’t think the supercharger pulley budged and now it’s damaged.
There’s a key in there. Maybe there’s a trick to getting this off.
Im ready to try to cut it off. I figure I might be able to use the dremel. Maybe an oscillating multi-tool. I’ve never used the one I have and not sure if they make a tool to cut through a pulley.
1.) Will a slide be an issue? (Will it get stuck?)
2.) If using E-85, Will a regular gasoline carb jetted fatter work (compared to one for methanol)?
We got rid of the intercooler.The blower should take care of any low flow for the intake. That’s kinda their whole intended purpose and reason for living. The biggest problem I see you having right now is every stupid theory you run into you try to build using it. The fact of the matter is not all things apply or are useful to what you are building. But you are just stubborn enough not to listen to experience. The long intake tract and blow through intercooler is costing you more power than you are making. You vaporize the fuel mix only to have it recondense in the cooler. Not good for making power. Not one bit! The long run also allows fuel to fall out of suspension. The distance between the carb and the blower introduces a lag time between open throttle and the hit.
If we were building 2 engines one by you and one by me I guarantee mine would make more power and be faster.
I already have a 30mm as well. It’s what I had for a 420cc engine. The 45mm UNI filter fit on the 48mm air horn of the carb with a little hot water to loosen it up. These carbs have a “power jet” which when the pressure drop in the air horn is enough it pulls fuel from the bowl and sprays it before the venturi/slide. I usually just replace the small fuel line with vacuum caps, but this is an option to dump more fuel at WOT I think. I’m not sure how this circuit really works. I always have just capped it and adjusted the main jet.If it's a little too loose, nobody would ever know. If it's too tight, everyone will know.
The carb should be sized for the power you intend to make. Engine displacement becomes a secondary factor with forced induction. I would probably be looking for at least 24mm if not 28-30. If you already have a 24, just try that first. A 25mm restrictor is enough for formula SAE cars to make 80+hp at the wheels.
Yeah, 10.4:1 with 11psi is a lot of squeeze for pump gas and a chamber that has effectively no quench. E85 would probably handle it.
The one on my (genuine) AMR500 is a very close fit, but slides right off once the nut is removed.
1.) I doubt it. Your blower can only pull on it as hard as the atmosphere pushes from the other side. It might be different if you were trying to push 11psi into it as a blow-through.
2.) It will take ~40% more fuel mass flow than gas, so make sure the carb can do that.
Bob, that is how you want your engine and blower to be. Nice and close to the intake port just after the carb. That will give you the lowest intake temperature, keep fuel suspended and best throttle response.Always wondered who made this one. View attachment 139847
Well I got to put timing somewhere to try to get it going.I might not sweat the timing too much until you get it running. But that’s just me.
