well since i havent gotten my paycheck to buy the tubing heres my engine:
11hp 399cc briggs & stratton, electric starter
Model:252707
Type:0632-01
Code:82100711
kinda happy since i opened it up to replace the base plate gasket and lubrication was modded or the engine is just like that i dont know but it had no lubrication just two wedges on the connecting rod so i'll give it a try as a horizontal. see what happens BTW remounting the carb while i'm at it.
but as always i have questions lol i should be getting on u guys nerves by now.
on the carb it has to butterfly valves, one was connected to the govener (which was removed) and the other to the throttle.
the one connect to the govener moves freely for now, but the throttle is spring load and is open at full throttle. does that mean my engine has to always be in full throttle? and what do i do with the other one take it out, leave it freely?
The one that is spring loaded should be closing at full throttle, and that is the choke. I really hate the chokes that close at full throttle, its just annoying, i suggest running two cables, one for choke one for throttle.
Heres the info i got for that engine according to model numbers.
made october 7, 1982, at factory 11
25 CI block
electric start with charging system
Plain no flange crank bearings.
Engine may be pressure lube, i know my 12hp kawasaki is. i'll try to pull up the manual for it to see.
