To setup the throttle for performance, remove all current throttle and governor components, the carburetor and airbox (leave the manifold thingy). Go on the web and get a cheap chikuni 22mm and filter, and a long enough throttle cable. The carb should almost be a direct swap, the throttle will be much easier to setup, and you'll have more power. Plus, the carb won't gum up as easily.
