Streaker S465 live axle resto
Bacon, if I was you I would have the remaining good wheels sandblasted then use the POR15 system and etch with the metal ready and paint with gloss black POR15 but before it is completely dry prime it with a laquer automotive primer and let it all dry thoroughly. Then scuff sand and paint them your chosen color.
Here are the ones I have, I have a third one somewhere around here.
Okay, all rested up and I can think now. It looks like you have one front hub and one rear hub and one no hub. Lemme get some measurements. Total tire height: 11.5ish inches. Wheel size: 7inch. Distance between mount holes: around 3 inches. I couldn’t get a precise measurement quick, if you need another more precise I can get it.
Found the last one. Yeah, I have both front hubs and non drive rear hub. No drive hub.
I remeasured and the hub fit is exactly the same as yours, the drive hubs I have for the rear axle would fit those wheels. I'll get both tires off the wheels this afternoon, to inspect them for unseen damage. Our wheels are identical in all dimensions I have access to at the moment. When I take them apart we can identify width. I'll also check the fronts for damage. I'm fairly certain (I haven't looked at the front wheels in a long time) that either the tires or the whole wheel assembly is smaller then the back. Thanks.
@Grizzlymi, any tips on getting tires off split rims? Just lots of screwdrivers and pry bars?
Edit. Watched a video, working now.
Couldn't get the tire off in the time I had, I'll try when I get some time. If y'all have any tips, throw 'em out.
