sparkplug shock
enel1221
Illionois
touching the spark plug will not kill you, maybe like 1 in a trillion chance. its like 30,000 volts but no amps therefore it'll hurt like :censored: but not strong enough to kill you.
my_mini_bike
We've all been zaped at least once..
Havn't we... :oops:
On one of my older engine is has an ex-ternal clip onto the spark plug, and the only way to shut it off is to manually disconect the spark plug lead...
Gets ya everytime. :censored: :censored:
_______________________
Can't think of a cool slogan?
Kenny_McCormic
Kartless....
Michigan Troll
Havn't we... :oops:
You need to pull off the flywheel shroud and possibly the flywheel if its points style ignition and add a kill wire. Another way to kill these is to short the plug with a sheet metal flap held down with one of the head bolts.
gocartkid
Bad Attitude
CT
The way I kill engines set up like that is a simple hand over the carb. Provided you don't :censored: up the tune and it doens't backfire, it works well and sure beats being shocked!
Kenny_McCormic
Kartless....
Michigan Troll
Thats a good way to wear out an engine, all your doing is flooding it which WASHES THE OIL OFF THE CYLINDER WALLS. Some people on here need to buy a kill switch.
jr dragster T
Cold place
I know I know i've washed down a 2 cycle before but there is oil in the fuel so that just gives it some "after run oil" But washdown on a 4 cycle is EXTREMLY bad.
gocartkid
Bad Attitude
CT
Yea I know, but as a temporary or emergency thing it woks. And I just wired up my engine stand for a kill switch so I don't have to do that anymore.
Magice
I'm meaning the actual tip of the sparkplug that ignites the mixture. I'm wondering how different it is than the lead.
Russ2251
AZUSA:Powered by LAWN-BOY
3 of my Briggs engines were designed to be shut off by closing choke. Nothing wrong with this practice.
Choking also tends to pull oil up past rings from crankcase. Kind of a reverse blowby.
sayre315
Rupp enduro
Oklahoma
it realy doesnt hurt that bad
you guys ever had those shocking pens that when you try to open it it shocks you?
it feel like that
