Jrgunn5150
Rudderless
- Messages
- 1,028
- Reaction score
- 12
Duckie is a she
Dukkie is a he
Dukkie doesnt know Duckie
Duckie doesnt know Dukkie does she
Well played, you will fit in here.
Duckie is a she
Dukkie is a he
so whats the ebay verdict? im lookin for more get up than go.
think donuts and drifting not top speed.
6" $79.90 or 7" $104.99
Oops!
Sounds like a whole lot of Dookie to me.
She always has a new yerf dog and Gearing questions too. LOL
I was wondering why these were the same questions yet again.![]()
The 7" driven has an even lower ratio, I think it's 3 something to 1
Get the 7" driven, it will give you more gear on the bottom end. Is the jackshaft attached to a plate under the motor? If the orIginal Yerf plate and jackshaft are in play I am thinking you can just remove the clutch, tensioner and sprocket and slap the TC right in its place.
The pics in post #5? the one on the right is not your Kart, right.
FYI Duckie is a "She"![]()
60/10 = 6
chancer pointed out that 6:1 with a CC is good for 15" Tires.
15" Tires have a 7.5" Radius.
You have 18" Tires.
18" Tires have 9" Radius.
(9-7.50) / 7.5 =
Your tire radius is 20% larger than what is generally recommend for the maximum size with 6:1 gearing with a CC.
So with 18" Tires you want a gear ratio 20% lower (bigger number, slower top speed, more acceleration, better climbing, ....).
1.2 x 6 = 7.2
You are at 6:1 and should be at 7.2:1
On the other post I suggested a 72 tooth sprocket if you keep the 10T CC and 18" Wheels.
Or I suggested smaller tires. Get 15" Tires if you keep the 10T CC and 60T Sprocket.
But I like the Torque Converter Idea the best.
Keep the 60T on the axle.
Depending on jackshaft size and chain size, you can usually get between 8T and 12T to go with your 60T.
That would give you anywhere from 5:1 to 7.5:1.
Lets say you use a 10T and keep the 6:1 and 18" tires, but now with a TC.
Lets compare the the Torque.
To make it easy, assume 10 ft lb at the crankshaft.
WITH A CC
6:1 Gearing with CC
18" Tires
0.75 Ft Radius
(10 x 6) / 0.75 =
80 lbs of linear force pushing the kart forward
7.2 Gearing with CC
18" Tires
96 lbs pushing the kart foward
20% increase
6:1 gearing with cc
15" Tires
0.625 Ft radius
96 lbs pushing the kart forward
20% increase
WITH A TC
Multiplies Gear Ratio by ~2.7
So 6:1 becomes 6 x 2.7 = 16.2 @ engagement
(10 x 16.2) / 0.75 =
216 lbs linear force pushing the kart forward.
NOW, the belt will cause torque losses. About 15-20%, so the 216 minus 20% =
172 pounds of force pushing the kart forward.
115% Increase
---------- Post added at 12:39 PM ---------- Previous post was at 12:31 PM ----------
LOL
https://www.youtube.com/watch?v=lLl0DVzRksk
Did you impeach and remove "The Governator" from office yet?
Is it possible that Arnold is is also limiting acceleration, not just max RPM. I never ran with a governor, but on videos - karts seems to pull harder when they reach back and over-ride it?
It doesn't seem like low end would be affected, but IDK?
How's Wolfie?
