Somebody do the math
Oops!
Sounds like a whole lot of Dookie to me.
She always has a new yerf dog and Gearing questions too. LOL
I was wondering why these were the same questions yet again.:roflol:
JollyKarter
Texas
Get the 7" driven, it will give you more gear on the bottom end. Is the jackshaft attached to a plate under the motor? If the orIginal Yerf plate and jackshaft are in play I am thinking you can just remove the clutch, tensioner and sprocket and slap the TC right in its place.
Jrgunn5150
Rudderless
This, the 7" will give you more donut power.
Dukkie
New Braunfels TX
there is nothing out back but the predator motor, thats one reason i asked does the ebay kit come with everything i need?
Dukkie
New Braunfels TX
The pics in post #5? the one on the right is not your Kart, right.
correct
left is mine, right pic is a minibike pic taken from google for example when i thought about adding more sprockets
---------- Post added at 11:03 PM ---------- Previous post was at 11:01 PM ----------
its bedtime, someone google me a shopping list and link me to what i need..
Staff Murderator
FYI Duckie is a "She" :thumbsup::p
Moron. Inserted foot in mouth, again.
That is a factual statement in and of itself, however misplaced, ill advised and of mistaken identity.
JollyKarter
Texas
Hellion, agreed on foot in mouth...the politically correct way to say that is "Duckie identifies as she"
Did you impeach and remove "The Governator" from office yet?
Is it possible that Arnold is is also limiting acceleration, not just max RPM. I never ran with a governor, but on videos - karts seems to pull harder when they reach back and over-ride it?
It doesn't seem like low end would be affected, but IDK?
How's Wolfie?
60/10 = 6
chancer pointed out that 6:1 with a CC is good for 15" Tires.
15" Tires have a 7.5" Radius.
You have 18" Tires.
18" Tires have 9" Radius.
(9-7.50) / 7.5 =
Your tire radius is 20% larger than what is generally recommend for the maximum size with 6:1 gearing with a CC.
So with 18" Tires you want a gear ratio 20% lower (bigger number, slower top speed, more acceleration, better climbing, ....).
1.2 x 6 = 7.2
You are at 6:1 and should be at 7.2:1
On the other post I suggested a 72 tooth sprocket if you keep the 10T CC and 18" Wheels.
Or I suggested smaller tires. Get 15" Tires if you keep the 10T CC and 60T Sprocket.
But I like the Torque Converter Idea the best.
Keep the 60T on the axle.
Depending on jackshaft size and chain size, you can usually get between 8T and 12T to go with your 60T.
That would give you anywhere from 5:1 to 7.5:1.
Lets say you use a 10T and keep the 6:1 and 18" tires, but now with a TC.
Lets compare the the Torque.
To make it easy, assume 10 ft lb at the crankshaft.
WITH A CC
6:1 Gearing with CC
18" Tires
0.75 Ft Radius
(10 x 6) / 0.75 =
80 lbs of linear force pushing the kart forward
7.2 Gearing with CC
18" Tires
96 lbs pushing the kart foward
20% increase
6:1 gearing with cc
15" Tires
0.625 Ft radius
96 lbs pushing the kart forward
20% increase
WITH A TC
Multiplies Gear Ratio by ~2.7
So 6:1 becomes 6 x 2.7 = 16.2 @ engagement
(10 x 16.2) / 0.75 =
216 lbs linear force pushing the kart forward.
NOW, the belt will cause torque losses. About 15-20%, so the 216 minus 20% =
172 pounds of force pushing the kart forward
115% Increase
---------- Post added at 12:39 PM ---------- Previous post was at 12:31 PM ----------
LOL
https://www.youtube.com/watch?v=lLl0DVzRksk
KartFab
you can get either a 7" or 6" driven. The 7" driven on the yerf dogs were powered by smaller hp engines than the predator, so a 6" driven is not a problem at all.
If it were me personally, id get the 6" and if i didnt like the amazing torque and speed, id just get a 9t or 8t jackshaft sprocket.
Also, the original yerf dogs had 20" tires so you are fine with a 6" and a predator 212cc because you have the 18" tires.
Dukkie
New Braunfels TX
60/10 = 6
You have 18" Tires.
(9-7.50) / 7.5 =
1.2 x 6 = 7.2
WITH A CC
6:1 Gearing with CC
18" Tires
0.75 Ft Radius
(10 x 6) / 0.75 =
7.2 Gearing with CC
18" Tires
20% increase
6:1 gearing with cc
15" Tires
0.625 Ft radius
20% increase
WITH A TC
115% Increase
LOL
Dude knows his math!
The sad part is i dont know the formulas but I read all that in 45 seconds and understand the differences of each one of the scenarios.
Jrgunn5150
Rudderless
How's Wolfie?
Of course we don't have dyno graphs for these silly little engines, but I have to imagine holding them below 3600, they never reach peak HP or torque.
