Somebody do the math
Dukkie
New Braunfels TX
Is this a possibility, taking what i have (first pictured) and adding some kind of sprocket reducer and a 2nd chain to drive the axle (second pic taken from google)
i have yerf dog 3202
as it sits
new predator 212
new 10 tooth centrifugal clutch
#40 chain
60 tooth sprocket
live axle
18" rear tires
as it sits it is sluggish like there is no torque for the first 15 feet then it will get up to estimated 25-35 mph (unverified)
Jrgunn5150
Rudderless
Paging Bob, Bob, please GAB on this guy's math.
FYI, I don't see any pics.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Pics on other thread. lol
60/10=6 6:1 gear ratio.
15" is the tallest possible tire.
If you continue to use it you will burn the clutch.
Jrgunn5150
Rudderless
Well that seems needlessly complicated.
Best bet is get a converter like Chancer said, if budget is an issue, get a large rear sprocket.
JollyKarter
Texas
The Yerf originally had a torque converter, that is why it had a jackshaft. The TC driven mounted to it. You can buy the eBay knockoff unit, but you would be better to spend the coin and get the Yerf replacement setup. Your standard 30 series has likea 6" driven...the Yerf came with a 7" driven, giving lower gearing on the bottom side of the TC, to make up for the tall tires. I know BMI has a Yerf specific replacement kit, I am sure other places offer it also.
Dukkie
New Braunfels TX
if i already have :
#40 chain
60 tooth sprocket
live axle
18" rear tires
I plug this into the Top Speed Calculator (MPH):
Drive Tire Diameter In Inches 18
Highest Engine RPM 3600
Number of Teeth On Axle 60
Number of Teeth On Clutch or Toque Converter Jackshaft 10
Calculated Results
Drive Tire Circumference In Inches 56.549
Gear Ratio 6.000
Maximum Speed In MPH 32.130
Im unsure how the math works, when adding a torque convertor that still puts out power thru a 10 tooth jackshaft gear to a 60 tooth driven gear wont i end up with the same gear ratio and lack of torque?
TC Specs
Drive Belt: 3/4" Top Width Asymmetrical Type
Drive Clutch Bore Size: 3/4" (3/16" Keyway)
Drive Clutch Engagement: 2200 Rpm
Driven Unit Dia: 7"
Jackshaft Gear: #40 41 420 10T
Jrgunn5150
Rudderless
No, because before the converter fully engage's you have an additional 2.68 reduction.
