solid or tubular axle?
freakboy
the names 'mater
hick town
whats on there right now? 1 inch? you might be able to get away with on inch solid chromolly.
junior
where do yall get parts? if i can find the good setup for the right price ill go with it.
junior
the way im lookin at it, im gonna put shorter tires and some suspension on it. i dont take it off road much (more of an incliment weather kart). and i cant find parts. the one inch is a direct swap from what i have now i can reuse everthing and be riding again sooner.
think im gonna get this
http://www.mfgsupply.com/m/c/AZ1401-54.html?id=kDHuXEG4
unless i can find a hardend one the same length or longer.
modelengineer
Lord of the noise
Sydney, Australia
I'd just buy from a steel shop. A bar of 4140 chromoly 1 1/4" 50" long was under $50 AUD, but I suppose if you don't have a lathe and mill it's difficult to put the keyways and threads on the ends. FWIW I think that axle will most likely work, but you never know. That is a hell of a lot of power, but maybe the spinning of the tyres and wheelies will stop you putting too much stress on the axle.
r_chez_08
Should be in the shop...
Cornwall, UK
yeah i know but the one incher is overkill for anything under at least 60 horse. regular cars use a one incher and they are putting down more power and moving more weight. they dont break.
actually wait... i got that wrong. 30mm mild steel, except for the stepdown 25mm ends. oops!
jr dragster T
Cold place
But remember in a car say a front wheel drive car it may have a 1" axle but how far away is the hub from the bearing assembly? 1" if that?
junior
ok so im gonna go with the 1 1/4. couple questions on that. were do i find wheel hubs and a solid axle?
