Snow Blower Transmission = Manual Kart?
l008com
Has anyone ever used a snow blower style transmission in a go kart to make it manual?
Before we go on, please understand that this is just a curious thought I had. I have ZERO interest in doing this, I think it would likely be a terrible idea. But it also seems like it would probably work.
So if you connected the aluminum friction disk to a clutch pedal, spring loaded it ON instead of OFF, then you would be able to shift gears freely, while moving, while the clutch was pressed. I don't know how long the rubber friction ring would last, but I assume not the 10ish years you can get out of them on an actual snow blower!
Another issue is that most karts don't have room for 3 pedals, so you might have to make it a hand clutch lever on the send of the shift lever.
In many ways this would be a terrible system but at the same time, I think it would be fun to play around with.
l008com
Ok I was thinking about this today while driving home from work and i had an idea to potentially make this work better.
Take a motor with a horizontal engine, but the shaft coming out of the top, not the bottom. Mount that directly on the engine plate. Then put a giant aluminum disk on TOP of the motor. At a much larger diameter than in a snow blower. Then a much larger diameter drive ring wheel with a thicker drive ring made of tougher rubber, more like car tire rubber.
I think this just might maybe possibly be able to work.
Again, I'm not building it, I'm just coming up with ideas. And this one... isn't *all* bad.
It may work on a snowblower that wieghs a couple hundred pounds and goes 3mph but don’t expect much more.
l just used a hydrostatic transaxle outta a ridem mower. Works great! Varible, gives whiplash if l stomp it. Reverse is lower gear than forward. I‘m really happy with how well it works.
l008com
Got any pics of this project?
OffRoadGoKart2024
No, but, they made riding lawn mowers aka Rear End Riders
I currently have 5 of them, using 4 of them to make a 6x8. The other one will just be a spare back up mower.
FWIW: The disc is steel. Plus, they appear to be chain drive inside the gear case. I will know the ratio once I open them up.
