BradenM
Etre Et Durer.
I've done some reasearch (http://www.google.com.au/search?rlz...urceid=chrome&ie=UTF-8&q=pocket+bike+no+power) and apparently it's quite common (google thinks so). New fuel filter, and fuel tank cleaning is the quick way out, and it gets into low compression (new rings minimum, sometimes rebore, oversized parts), new spark plugs, e.t.c.
I would suggest pulling the head, cleaning your piston with seafoam (flashlube works reasonably well for aussies, soak over a period of 12 hours, fire it up, and again until clean) or equivalent, and cleaning up exhaust valve and combustion chamber fouling. Then, apparently, crappy manufacturing can send plastic fuel tank fragments through filter into carb-it is possible, though unlikely, that your carb got clogged after cleanup and rebuild. I would also suggest trying the bike without the exhaust on. If it runs as it should, you have an obstruction in your pipe. Replace with double header and your laughing.
