shifter kart II
Ognib
bingo spelled backwards
kc
Notched & fitted together & ready for some tacks.
There will be an additional cross tie tube later.
It will also be the mount for springs & shocks so not sure on final position on it yet.
Ognib
kc
Thanks.
Quick, accurate repeatability is the key when you've only got to build 8 of them just alike...
SteelHorse
Very true. I also do my length cuts double stacked. Same cut guaranteed on both parts. especially angles. But hats off to you with the round tube. I’m not there yet. Using rectangle tubing for my frame.
Ognib
kc
I've always admired the tube framed cars...especially the fuel altereds in the early days & the sprints, as well as the full caged road race cars.
Round tubing is one of the things I've never tried but always wanted to do. Now's the time...see if I can pull it off.
Being retired, I no longer have the budget for a full sized car. However, the skills & technological challenge is just as great on a smaller scale build.
Ognib
kc
Hot to get the first a arm stuck together. But first I needed to cut another plate to have a duplicate to use on shaping the remainder of the parts.
Ognib
kc
This is the point I've been working towards for several days now.
SteelHorse
Coming along bud! Keep at it, good luck with the round! I just don’t have the tools to do it!
Ognib
kc
Thanks for the encouragement. :cheers2: Always appreciate & enjoy any input on the project.
Ognib
kc
Two of them tacked & #3 being fitted.
By the time I drill, cut & dress the plates along with cutting & fitting the tapers on the tubes, takes about a half day to do one.
I'm havin fun here, how bout you? :cheers2:
Ognib
kc
Appreciate the comments.
Jigs are essential to building multiple pieces.
A glimpse ahead.
Since 90% of the plan for this thing is in my head, mock ups help me to solidify my visualizations & determine how to proceed.
I planned the a arms to be ambidextrous so the uppers could be flipped over to mirror the lowers
Ognib
kc
I broke down all the mock ups, lifted the engine & cradle out of the way & X measured & adjusted to assure that the frame is square.
Also used some string & Xed the opposite corners to verify that all corners are level.
Highly satisfying after all this preparation & planning time to actually be welding stuff together.
Ognib
kc
Thought for the day
Measure twice, cut/weld once. You can never do enough prep work before you make that final (and often non-reversible) cut or weld
Ognib
kc
I may have found the answer for a chain driven limited slip differential. Pics are of a Subaru diff. Seals & bearings are enclosed in the case. Pics show with sprocket mounted etc.
I have a mechanic friend that has driven Subaru for years. Hoping maby he has some stuff laying around that I can use for my project.
Ognib
kc
Got the rear wheels.
Should have differential, wheel hubs & axle shafts in about a week...start fabbing it all together.
