Sequoia Electrathon Racer
Workin' on gettin' the 3-wheel brake system installed ;)
Got the master cylinder mounted
Had ta adjust (1) of the brake likes to clear the chassis
Got the front calipers installed
* First, I got a "feel" for how easy the kart rolled, by hand :thumbsup:
...then, after installing each caliper, I gave 'er a "test roll" to see if I noticed any additional drag
...& I'm happy to report, I didn't notice any additional drag :sifone:
Got the rear caliper installed, as well
I'd say a couple of systems checks
...& she's about "ready to rock" :auto:
System check
First, checked for continuity & voltage level at the battery pack...yup ;)
Then, "connected 'er up
...but, with the system not connected to the speed controller...yet
Next, I checked for continuity & voltage level back at the SC connector
First with the circuit breaker in the "Off" position...nope, no voltage present (see pic)
Then, with the breaker in the "On" position...yup :thumbsup: (sorry no pic)
Then, "flipped" the "On/Off" switch to the "On" position
The system came "on line" :wai:
...& the power meter "says" that we have ~55V in the battery pack (currently at storage charge level, needs ta be fully charged)
That video was not all that interesting. Sorry man, but you’re no Cecil B. DeMill. I was hoping it would be something interesting it was going to be of something with more drama. Like you squeezing into the kart. One question though, where does the big red triangle go for the power button? Now get out and charge it up and try it out!
Hey Denny,
Sorry, I can't "flip" every kart for ya :eek:
...& no drama entering &/or exiting the c*ck pit either :innocent:
"where does the big red triangle go for the power button?"
The red triangle will "go", on the outside of the body
...just below where the CB is mounted
There will be a "pull string" attached to the lever of the CB
...that when "pulled" will de-activate (turn off) the CB thus "killing the power" ;)
See, I knew if I jabbered enough
...you'all would (accidentally) learn about "this" stuff :thumbsup:
Hey Denny,
Aaaaahh! I need brain bleach now! I’m learning! :furious2::mad2:
