Sequoia Electrathon Racer
Been cleanin' up the chassis after weldin'
...but, had ta take a break (my arms are "killin' me)
So, I worked on Throttle Control Assembly ;)
TCA Components
...pedal
...cable connector
...cable mounting bracket
...cable end/adjustor
...cable/housing
...electronic Hall Effect Thumb Throttle (mounted on a "peg")
Frontal components
Rear components
Kinda like this
* Notice the throttle pedal return spring
...which gives 'er a nice firm feel
...& also provides a good-n-snappy "return action" :thumbsup:
When is the big race Speed Racer?
Hey Denny,
Well, the Electrathon race nearest me (~100 miles away, in Michigan) is/was this weekend o_O
...but, my daughter's graduation is/was this weekend too
She is one of the top 20 of her graduating class (I'm so proud of her) :sifone: :banana:
...&/so, family comes first :thumbsup:
FWIU they run EA races down in Florida about every weekend
...but, Ima been havin' a super-hard time convincing my wife that we should go on a ~1,000 mi. road trip
...just so, I can "race around" for a couple of hours :huh:
* BMI karts, here in Ohio, has an indoor track
...so, I've been thinkin' about tryin' ta convince 'em to "look into" the EA program
...& maybe even "set up" a race or 2 :cheers2:
The throttle cable needs to connect to the throttle pedal
...but, IMO it's best to try-n-keep 'er off to the side
So, I used a 1/4" x ~3" bolt as a pedal to cable connector
Clamped 'er to the workbench
...& drilled a hole, for the cable ta go thru
Like this
Installed, it looks kinda like this ;)
Also, notice the pedal stop
...so, the pedal can be floored without exerting excessive pressure on the Thumb Throttle
(pedal at rest)
...& (pedal engaged) in the WOT or full throttle position :2guns:
I admire the skill it takes to drill a hole in a bolt by hand!
Have you ever tried a center drill to start difficult holes?
Hey T,
Thank ya sir :cheers2:
No, I've never used on of those
...but, I'll share the way I do it :thumbsup:
First, it's hard as heck, ta get a drill bit to "start" on a rounded surface without an "aid"
So, I use a spring-loaded center punch
...ta "make" a divot or dimple (kinda like this)
Then, ya can use the dimple ta help keep the drill bit "in place" & "drill baby drill"
After ~30 seconds I stopped drilling, to show ya what the divot looks like, after the drill bit "gets started"
Also, ya gotts ta do lots of "eyeing", while drilling, to try-n-maintain the proper angle
Another view (inverted)
After lots more chassis clean up, I gave 'er a good wipe down (a couple of wipe downs actually) with paint thinner
...then, layed 'er on her side
...& started paintin' :thumbsup:
Let 'er sit ~1 hour
...then, set 'er upright
...& did some more paintin' ;)
* Notice that a F'in bird sh*t on my fresh paint :mad2:
Sorry Kevin, but I almost peed myself laughing!
Well, maybe it was because I have a weak bladder. But I think you just got a name for the kart.
The Bird Sh¥t Kart
Target Practice
Gotcha
Bulls Eye
One In A Million Shot
Splat!
You know that bird went back to his friends and said “you guys ain’t going to believe this”.
The Bird Sh¥t Kart
Target Practice
Gotcha
Bulls Eye
Splat!
Hey Denny,
I'm glad I "made your day" :cheers2:
....but, a little soap & water
...& it's like it didn't even happen ;)
I came across an old refrigerator with stainless steel doors
So, I harvested me some SS :thumbsup:
I'm thinkin' "free floorboard" :bannana:
Front side
Back side
* Inside of refrigerator doors are full of Styrofoam
...but, it scrapes off pretty easily :wai:
Scrounging and recycling at it's finest. Fact is I believe you have taken the art to a new level!
Hey T,
Thanks!
They say "one man's junk "is" another man's treasure"
That frame sure looks purdy after that paint job, bird shyt and all!! Fantastic project you have going!
Hey Grizzlymi,
Thanks!
Some stuff (like a bird shytin' on my fresh paint) just makes ya "shake your head"
...& think to yourself "really??" :huh:
It'sa startin' ta come together :cheers2:
While the chassis paint wasa dryin' I started on the sub-assemblies
Swing Arm
* When ya see loc-nuts its "for real" this time ;)
I started installing some of the sub-assemblies onto the chassis :wai:
Up in the front, we installed the A-frames, bushings, shocks & their required hardware
Back in the rear we installed the swing arm assembly with its bushing, shock & required hardware
* Got ta get more 5/16 Loc-Nuts :huh:
Next up was ta bolt the wheels on ;)
Now, we have a "roller" :bannana:
Frontal view
Side view :2guns:
Another view :sifone:
