Sequoia Electrathon Racer
An advanced feature of the rear hub is the patented "key keeper". The design was invented cuz many of our customers have demanded it. It makes the hub idiot proof. And believe me the idiots here at the mountain top need all the help they can get. However nothing is fool proof to a sufficiently talented fool. The skunk works engineering department incorperated this design in your drawings for no extra charge! (not to say you need it, but an opportunity to share this advanced design)
As you see in the pic below the "round key" slot is open on both ends. In the event of a dumba$$ mistake ERRR AHHH, I mean a pit crew member oversight, the key could "potentially" come out and be lost. It would require the perfect storm of dumba$$ery to make that happen, but the potential does exist.
The new "key Keeper" design Locks the key in place. Even in the event the dumba$$ does not tighten the set screw properly the key cannot escape!
This design has been a standard here at Scrap Yard Engineers for years. Cuz we be the ones making the dumba$$ mistakes!
Been workin' on swing arm parts :thumbsup:
Made up a 10" spacer (ta space 'em apart) :cornut:
Marked the center of the (2) pieces
Trimmed the ends off
...clamped 'em together (with spacer)
...& then, welded 'em together :2guns:
Well, I think I'm done with this little project.
Here's is an interesting tidbit for your memory banks.
We all know about welding can cause things to warp, pull and move in ways not wanted.
In this case I tried an experiment ( I like experimenting with other people's stuff.) The wheel flange was heated and pressed on the hub. At that point I checked runout and saw .018 "wobble" with some strategic welding and cooling I was able to reduce that to .005. Much easier way of trueing things up.
I think I'm 'bout ready to send this stuff back.
Hey T,
Short, sweet & right to the point, purty clever! :2guns:
...& I can't wait ta get 'em :banana:
I got the swing arm "tac" welded together
Double checked that the upper "part" was "true"
Checked "fitment" with "mock" rear hub
Another view
* the spacer on the end of the spindle was so I didn't have to "run" the retaining nut all of the way down the threads just for a "fitment" test ;)
All ready to get the bushing holder welded on :cheers2:
Made sure everything was purty square
...& got 'er all welded up :thumbsup:
Mounted the hub & wheel
...& WTF? :furious2:
Um..."Houston we have a problem" (an old space reference-kiddos look it up) ;)
The wheel isn't centered in the swing arm (seems ta be off by ~1") :mad2:
Well...Ima gonna have ta do some thinkin;
...so, we'll get back ta that :popcorn:
Remember way back when I removed the top (post #150)
Next, I tried a couple of roll hoops
But, wasn't impressed/didn't like 'em :(
...so, lets try somethin' different ;)
I gots an idea from watchin' some of them Aerodynamic videos
Maybe somethin' like this :sifone: (styled after an F-1 Halo) :innocent::2guns:
is that a bushing? looks like an easy fix....View attachment 146783
Hey T,
Nope, that is just a "spacer" that I used, to not have ta "run" the nut all of the way down, just for a quick test fitting
We can't just adjust the hub over a whole 1"
...'cause where the caliper will be mounted, dictates where the rotor need ta be :thumbsup:
My right brain tried to say "It'll be fine"
...but, my left brain was like O-He** NO :mad:
...& "get your azz back out there & fix it" :eek:
So, I had ta "bite the bullet" & attempt a modification :surrender:
OMG this SUCKS! :furious2:
...such a purty weld :cheers2:
...& I have ta ruin it :mad2:
So, I used a cut off wheel, in the Dremel to try some micro-surgery :cool:
...as to try-n-not remove much material from the ends of the tube
...& also, ta try-n-not gouge &/or scare up the bushing holder too much ;)
Also, removed the offending 1"
...from the center of the upright section :thumbsup:
Clamped 'er together
...& re-squared 'er
...& then, re welder 'er up (again)
* Notice we have ta use a 9" "spacer" now
Also, double checked the spindle squareness, again
...& then, trimmed the bushing holder down (~5/8" extending out each end)
