Scrap yard save Lets make a roller...
B.M.800
TheBeal.
Central PA
Well its closer to being a roller again...
Now I need an axle. What do I use? Could I get away with a length of threaded rod? Length of cold rolled? Or should I look into getting a length of some fancy stuff?
Don't use threaded rod. They snap easily as they are made from bad quality steel. The threads all act as weak points too. The threads also mess up bearings. Rather get a length of common variety mild cold rolled steel
B.M.800
TheBeal.
Central PA
Well, I found a chunk of 1/2in that was in its previous live an axle for a dolly or something. Ran a die over both ends, one side more than the other. The short side I tightened up the nut and welded it on the axle.
Went to bolt it all up and realized I needed some spacers. Dug out the chop saw, and then faced the pieces off on the lathe.
Now its officially a roller again!
:wai:
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
:wai:
Congrats, you get a Snickers...( take that which ever way you wish!):lolgoku:
B.M.800
TheBeal.
Central PA
There is a lock washer on there... I was also contemplating putting a couple drops of lock-tite on it aswell.
I could also put a drop of weld on it! :roflol:
I think it will be alright for now, if I find I need to tighten it up on occasion Ill get something else on there.
Now onto the engine...
B.M.800
TheBeal.
Central PA
Hey who asked you :D
I found a crack in the mounting plate... gotta get that replaced now.
Guess I should start working on the engine now huh
B.M.800
TheBeal.
Central PA
Like this?
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
No, your guns actually have to shoot to do that.
(Not to mention whatever you're riding on!):lolgoku:
You could go on top of a High building, and pelt people with gun, minibike, and Jeep parts!:lolgoku:
B.M.800
TheBeal.
Central PA
Yeah yeah whatevs... :D
So, Ive got 2 engines here. The look about the same, but got different numbers.
Funpower numbers: 136212 0006 01 95062627
bashed in numbers: 135202 0015 01 960611YA
I dont know what all the number mean offhand, but would one be better than the other? Aside from the bashed in shroud ofcourse. :roflol:
