For any of those that would like to know.
I just recently purchased a rebuilt Tecumseh HH100 10 h.p. motor in case the one in my 69 sears tractor went out.
Well, it did finally go out(through a rod) and I put the rebuilt one in,I found out that the rebuilt one was a different much newer one.
I got it to running barely but it had a vacume leak somewhere, after some close scrutiny I found that you couldn't use the old carb on the newer models without an adapter plate because the carb bowl hits the side of the engine block and won't let the carb lay flush on the intake.
So, I traced the carb intake gasket out on sheet metal(1\16) and made 2 gaskets and placed them between the old gaskets and that fixed the problem with no probs what so ever.
I ran the tractor for about 3 hours today and no vacume leaks or overheating at all.
I bought a new 13 horse for the tractor this week but wanted to get the 10 h.p. running so I could put it on my kart because it has a starter\gen and then I can run full lights and run the reverse gear box.
The plan is coming together.
