BrownStainRacing
- Messages
- 1,367
- Reaction score
- 1,486
You will need 2 of those check valves, jus 1 still leaves alot of pressure in the crankcase.Ah, gotcha. I’m very familiar with catch cans. Had an IAG on my WRX before I sold it
Head gasket is +.010. I still have the vent tube coming from the valve cover. Since I took the vm22 from the old engine and put it on the new one, I took the new OEM air filter, cut a little piece out, and stuck that in the end of the valve breather. Did the same with the gas tank breather too. I will def buy a 1 way valve on eBay. Thank you!
At this point, I feel like you’re my small engine consultant! Minus the pay. Feels more like Lt Dans new legs actually.
When you get those check valves pull the valve cover off and pull that whole plate, that's holding the baffle in, out. Drill another hole in the valve cover, between the rockers, so you can add a nipple to connect to the 2nd check valve.
With the +.020" rod and a .010" thick head gasket, you created a catastrophe jus waiting to happen.
That +.020" rod moved the piston up to top of deck, now you have .004"- 0" piston to deck height. The .010" makes this .014" -.010", this is not enough. These cranks, rods, side covers will flex at higher rpm. That piston will hit the bottom of the head, and that's not gonna be a good day. The magic, safe number we are looking for here is .030". Put in a .027" head gasket with copper gasket spray and you will be fine. Put harden flat washers between the top of the head and the head bolts, only 1 for each head bolt. this makes a better seal on the shim head gaskets.
The last time I had a piston hit the head was with 0 deck height with a .018" gasket. About 6500 rpm. It smashed the bottom of the billet rod, broke the cam gear off the cam, and broke the side cover. When I tore it apart there was only a small nick in the piston and the head. It only took 1 time for the piston to kiss the bottom of the head.
Do you have the stock non hemi dished piston or the stock hemi flat top piston?????
