I’d like to see pictures of the carnage.
Yea me too. Cause theres way no that can happen with these pushrod engines.
1st, the compression release is on the exhaust lobe. If you lost .015" on the exhaust lobe, that means you now have .015" + valve lash on the exhaust side, the compression release would NOT work when you try to pull start it, and will bruise your hand, wrist, if not break it..... you will give up really quick and try to figure out why it's so hard to pull. So this .003" lobe lift doesn't make sense.
Now, when you start getting around .025" valve lash on the exhaust side, the pushrod will pop off the rocker arm and not open the exhaust valve. So the intake charge will come thur the intake valve seat, because the intake valve will open, get compressed, and then what??? It can't go out the exhaust because the pushrod is off the rocker arm. again you would not be able to pull the rope.
Something jus dont jive with this.
