Post your kart videos here!
I didn't see it was a Sachs...thought it was an Axrio rotary...those I know are close to $6500 new but the Sachs yeah $200 or so seems doable.
I'm curious on those, do you need to look after the Apex seals like one would on like the RX8/7 rotary engines?
Desertduler
The apex seals are holding up very well on this engine, I feed it Maxima K2 two cycle oil mixed at 25:1 and I use a foam air filter treated with Bel-Ray Foam Air Filter oil to keep the dust out of the engine otherwise it would not last long running on the lake bed, I have more than one of these engines and other rotaries of different models and displacement.
The Aixro XR50 engine uses the same size of apex and side seals as this Sachs KM24 engine and they even offer them in ceramic.
gallagher19
Fonthill, Ontario, Canada
1happydude
Bristol, CT
First spring ride!
Here is a video from our first spring ride. It features my Manco Deuce and my brother in law's scorpion 250. Mudding anyone?
75matador315
cato,ny
https://m.youtube.com/watch?v=HjVXRYMpRsY">https://m.youtube.com/watch?v=HjVXRYMpRsY" type="application/x-shockwave-flash" width="425" height="350">
here is a video of it running working on getting it moving. When i do i will upload a new video of it driving.
75matador315
cato,ny
bob58o i drove it around the yard a few times but the chain came off and ripped the clutch slave cylinder off so i figured before that happens again im going to change a few things. And yes i cant wait to actually be able to lay into it a bit.
75matador315
cato,ny
haha no nothing like that this kart feels fairly stable and sticks to the ground well. i pretty much just stopped moving and looked back and saw oil coming out of the motor. is that your kart in the video?
mkIVgladiator
upstate albany New york, united states
no childish cost-effective designs here but being light matters
my build was set up to be immune to rain or lakes but still spin free .... its a single seater ... brakes are yet to be installed. All of the go-karts videos above are probably worse rides than this one.... this one seater has a dynamic single coil suspension and tops out at 40-45mph friend clocked me going up hill on a road. This go kart has....
-$90 heavy duty ebay 1 inch bore clutch has been re-engineering
-$50Tecumseh 10hp motor off of a snowblower ...purchased
-$80 go-kart complete chassey wheels and everything else off craigslist
-$5 bicycle cable attached to gas pedal.... throttle has a retract spring
https://www.youtube.com/watch?v=WxDqIMmhPXA&feature=youtu.be
https://www.youtube.com/watch?v=zD30fBeGenw&feature=youtu.be
https://www.youtube.com/watch?v=XOwl2ZJoCQg&feature=youtu.be
https://www.youtube.com/watch?v=Kf02cmZQ0aQ&feature=youtu.be
In MOST of its GLORY!!!
Predator 212cc Hemi- Harbor Freight 60363
Black Mamba Jr Cam - SmallEngineCams
Ported Intake (80 grit)
Polished Chamber (320 grit)
Ported and Polished Exhaust (Black / White Rouge)
Ported High Flow Exhaust Header
Matched Exhaust Gasket
Head Milled 0.037"
0.027" Multi Layer Steel Gasket
11.11 : 1 CR
gx390 Carb
0.026" Idle Jet
Fuel Screw 1.5 Turns out
0.042" Main Jet
stock gx390 ETube
Gravity Fed Carb
gx390 to gx200 Carb Adapter - NR Zero Degee 2 piece
+0,020" Billet Connecting Rod - ARC
0.004" Piston In the Hole
0.031" P2H Clearance
0.080" - 0.090" P2V clearance
26 lb Valve Springs
SS Valves
High Flow Air Cleaner
AR3910X Spark Plug
8 degree offset woodruff key
32 degrees BTDC Ingition Timing
Automotive style retainers, keepers, lashcaps
Grade 8 Head Stud Kit
Crank Case Stud Kit
Custom Reversed Throttle Plate
No Gov.
No Low Oil
Remote Kill Switch
Fuel Tank Vent with filter Added
Inline Fuel Filter
1/4" Fuel Injector Line
Valve Cover Breather Filter
100 Octane Gas
10W-30 Oil
Stock Crank, Lifters, Pushrods, rockers, piston, and Flywheel.
Starts first pull warm or cold.
Choke on.
Cracked Throttle
1 Pull
Move choke to run.
Max RPM was 6600 (47mph) with 7.5 gear ratio, 30 series TC, 16" Tires.
Really starts going around 3k RPM.
Not positive if it is the TC upshifting or the CAM / Carb combo starting to make Power at 3000 RPM.
https://www.youtube.com/watch?v=mHmKX4cKU2w&feature=youtu.be
http://www.diygokarts.com/vb/showthread.php?t=32385
Where's the dirt?
Don't you teach right turns?
---------- Post added at 08:49 PM ---------- Previous post was at 08:45 PM ----------
My feature win a couple weeks back. Yeehaw, we changed our racing day to Saturday nights. I think it went well. Whatcha think boys
https://www.youtube.com/watch?v=5LgRm5H2sNghttps://youtu.be/5LgRm5H2sNg&feature=youtu.be
I was sure he was waiting with a red shell. Wait for you to pass, then POW!
