Lol way too wacky and would be a garage engineering nightmare to figure out how in the heck it would be driven. Probably needs a planetary type gear set to make that work properly.
In the background. Is that yours too? Looks like a single sided ront fork with a chain drive similar to a Rokon or the likes.
So with running tandem axles, where would I set the Ackerman angle at, the middle or rear axle?
I think the functionality of akerman angles goes to shot with 4 drive wheels in the rear. The double the traction and turn radius scrubbing will make for some wonderful understeering.
I found the transmission off the diesel 6x4 on eBay for $1200. Doesn't look like it comes with the CVT parts. Didn't see anything about the locker at all. The chain drive hubs are $95 each, so not too terribly expensive on that. Maybe if I can find one locally that's being parted out that may help a bit.If you could find the transmission out of a 6x4 gator, those had a lockable diff with forward and reverse, and they were chain drive to the wheels if I remember correctly...
I believe the transmission has the internal diff, with left and right axle stubs. The front driving axles were driven directly by half shafts, and the rears were chain driven off the fronts. It could probably be made to work without too much effort.
That R/C diff that was shown on here would be kind of the ideal setup, where the half shafts would be in the middle of each side of the walking axle, with sprockets hooked up to the wheels. I'm not sure I get what you mean by them not being independent from each other.IIWM, I'd use a diff as the primary drive & have an independent "outrigger" setup...
Having a walking axle is one thing but, if you hit uneven terrain, as in, one side is climbing when the other side is dropping, there will be traction loss, with wheels leaving the ground surface; having each side independent of the other will eliminate this issue...
I think you are saying, have the rear end be more like trailing arms instead? So instead of walking axles, have the rear be completely independent of each other? But then what of the front end?IIWM, I'd use a diff as the primary drive & have an independent "outrigger" setup...
That was my thought too. While that does make it a bit easier, it would not go very well over uneven terrain.Sounds like he interpreted it as the rear axles both doing the same thing, not independent of each other, as though the walking beams were a subframe.
I had another thought, could a live axle in the middle where the axles pivot and use it as the pivot point work? It could help minimize the amount of parts used vs having the jackshaft built on the frame doing it that way. I could possibly in theory have the walking axles sealed and run 80w90 gear oil in them. At least then with it sealed, no worries about debris hurting parts of the drive line.
Glad I asked then. The part that I may be overthinking is then, with the live axle then being the pivot what would be the best approach to allow it to spin freely while being through and through the walking axles? I really need to get parts ood this drawn out so it can make things easier to explain.Not only would it work, it would be by far the most practical means of doing so. I don't know about the sealed beams, but using a live axle as the pivot point with axle bearings in the beam would massively simplify things, and make chain tensioning a non-issue.
