Please help me!!!
steezy
russ im with you, ive heard so many mixed things on direct drive i just truly want to know IS IT BAD OR GOOD!!?? lol
r97
Measure twice cut once
Massachusetts, USA
i mean with a rateo the engine cant handle at take off. and coasting would be slow bwcause of the drag on the engine
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
according to the speed calculator, at idle you would be going from 20-25mph with a top speed of 50mph.
steezy
**** alright well the cog is already on its way so basically i couldnt be going any slower than 20mph unless the engine is off?
r97
Massachusetts, USA
either that or put it up on blocks then pull the recoil which will be harder because of the drag from spinning the wheeles with such a high gear
r97
Massachusetts, USA
yea i guess devino is right i idnt think of tha its not like you can pull start an engine at like 2000rpm. and buy the way i hope you can jump nto the kart qwickly lol, wait not lol that would be bad
devino246
Lynchburg, VA
He needs to find himself a nice hill. The only problem is getting it there.
r97
Massachusetts, USA
yea pushing a cart up a hill while lifting up the back tires or pushing agains the engines compression and drag through a 1 to 6 rateo, ummmm....., no. plus the extra drag from the wheels and engines compression ect would mean it would take a while to get to speed and that = bigger hill which = more pushing kart up hill which = ugg which = just kidding this time lol
fowler
Bullsbrook West Aus
if u cant pull start the engine cause it is too hard and it is to hard to push it and jump in then put it on blocks and wrap a rope around the wheel then u get better leverage
r97
Massachusetts, USA
good point but you would need to pull the rope way way way faster than normal. and we were thiking of starting it by coasting it down a hill which still wouldent be easy youd have to go soooo fast to get it started
