Offroad big block buggy
Eztrail
Cleburne, Tx
Thank you, and you would be correct. Tabs are .125.
On the first generation of this machine I did most all tabs in 3/16 and it was overkill. When looking at how my rmax1000 is built and what I put that through, .125 is PLENTY if done correctly.
Eztrail
Cleburne, Tx
Thank you, I normally overbuild things. On this build I'm trying to keep weight in check as I have a weight and performance goal. Even so it'll still be overbought. I took ideas for the trailing arms from several designs I saw online.
Eztrail
Cleburne, Tx
Yes, lots of people use full length miata axles but I think its way too wide. If I used them full length id be 64" wide. For reference my rmax1000 is 65" wide and it'll go anywhere and has a way higher cg than this kart.
