New minibike build, and a few others..
Raywelder
Not an Adm¡nistrator
Okay guys, Just got a couple digital cameras on ebay, So should be getting here soon. So Now I will be able to post way more pics. I will probably start a new thread for the buggy.
Got the gear box today! Woo,
So small and yet So Darn heavy.
Kaptain Krunch
Pro Junk Collector
vermont
Nice, PICS
Well
Just got a steering rack off my buddy for free.
Came off a 88 mustang.
Man i'd sell the rack, im sure you could sell it and buy another from a junkyard and still make a decent profit. A rack from a stang is going to be worth way more than a rack from a Toyota!
Raywelder
I doubt it!
I cant see this rack being worth much.
Raywelder
What kind of right angle gearbox did you use?
Got it on ebay, Its a 1:1 worm drive, with 5\8" shafts, With outputs on two sides. Its smaller and will work better on the bike.
Its fairly small but it weighs like 15lbs! Im pretty sure it weighs more than the original box.
Raywelder
Doing some garage cleaning, arranging it so my two projects are more work-on-able lol.
Camera coming soon, Pic updates to come.
Raywelder
Ok guys, got a camera, Hurry for halfway decent pictures!
Haven't done anything to it lately, I need to hit tractor supply for a few things before I proceed, and also pick up the shock I just bought.
ZnsaneRyder
Crazy Guy on a Bicycle
FL
That's one awesome setup there! Twin Briggs on a motorcycle! SWEET!
It will sound like a HOG! Those twins are great. Good job on the build, can't wait to see the end result of your hard work!
Raywelder
Ha Thanks man,
Yea it should sound good, I'm not using those headers though, I built those for my go cart setup, but I will be building a new exhaust out of the pipes laying all o ver the ground there.
Raywelder
Heres the caliper I'm using for the rear, originally picked it up for the gocart, But decided to use it for the bike since its more suitable for a bike anyhow.
Im trying to get a dual set to match for the front.
Raywelder
More goodies! Got some shocks from a place in town. The guy there has tons of bike parts, and he sold these to me for 10 bucks a piece,
The one of the left is for the bike and the two matching ones are for the cart.
Raywelder
Bottom mount tacked,
Welded
I had to reweld the top mount several times. I had to adjust it so its sprung a little high to compensate for the motor, gas tank, transmission and rider weight.
And I might still have to move the top around some more. I will figure it out later when the engine and everything is bolted on.
jr dragster T
Cold place
Just a little tip whenever you tac a real tac is 3 seconds long to get enough heat into it to hold anything. Also clean your material off a little better for stronger welds. Most people think 1 second is a tac weld.
Raywelder
I've been welding for a while, and Now I weld a lot at work. The welder at work is a serious welder though, The one I have here is a little flux core wire welder, It just doesn't weld near as good. But the welds on that plate are strong, just arent as pretty as a mig.
And yea I know, I didn't get too excited about cleaning it off, but cleaned it enough to get a solid arc.
Khyren
1 solid second on a mig set for spray transfer will hold just about anything for a good while. Where I work, most everything is set on 29.5 volts and 700 wire speed. So 3 seconds at those settings, you burn through anything under 1/4". We weld wide open on just about everything. I must say though, it did take awhile to learn to weld that hot on 16 and 14ga steel. I made a lot of holes that first day doing that. 11ga and wide open is normal for us and we are quite good at it.
Khyren
