New build in progress
WillMatrix
Yes, that's it :thumbsup:
In the pic of the frame, with "the string", notice where the string & the red rod criss-cross?
...that's where the outer tie rods need to be attached, to have "correct" Ackerman :cheers2:
Completely random but would you be able to get me a blueprint of that kart design?? Plzzzz if possible
You are a beast man!!!!!! When it comes to the spindle area should I raise the pipe up like the racing karts?
Thanks! :cheers2:
...as you can see, I do this...a lot ;)
I raised the pipe up in the front so, the front spindles would be at the same height as the rear axle
...this way the frame of the kart would be/set level when riding/driving :thumbsup:
* This kart was to be a "ground hugger" (for better/increased maneuverability at higher speeds)
...& I must say, it stuck to the "track" like a magnet :2guns:
** It's actually the best handlin' kart, that I've built...so, far :sifone:
