Need Help With Tecumseh 3.5hp
tenlizard
ok i get the point...i got it off yesterday however when i wanted to reassemble it...the nut wouldn't go on correctly...i tried the wrench and it stripped the whole nut...i'm going to buy another nut today and see what happens.
Russ2251
AZUSA:Powered by LAWN-BOY
Probably damaged from hammering with metal. Inspect threads and use a thread chaser otherwise another nut will be lost. Might wanna check for bent crankshaft end.
tenlizard
just bought a new crankshaft on ebay. 23.00 shipped. i tried the thread chaser, however, it didn't work. it was the correct size and thread and everything. it was a 7/16" 20. it was a huge pain in the @$$!
jr dragster T
Cold place
You give up and buy a new crank holy cow. It'd take me 10 minutes and carefull filing. Glad your not remove my flywheel on my Rhino engine. $450 crankshaft!
tenlizard
then what's the proper procedure on removing a flywheel without damaging the crank?
