ok i cleaned the carb and fixed it, cleaned the head, gasket, valves and piston. finally i got it running great. then i forgot that i took the oil out and it ran, then it smoked an siezed. i took the compression and it said 25psi before it was at 75psi. i tried to start the engine but it wouldn't start again. i took the rings off the piston and put them in the cylinder...the gap with the rings wouldn't touch they were missing by like .10 of an inch. i don't know if it was the cylinder that got worn down or the rings worn down...how can i tell...i looked for repair parts on the tecumseh website and they didn't have new rings and i am pissed
PLEASE HELP! It won't start because of the too low compression.
