My first Kart Project
n3480h
NW Iowa
Look through the Stickies - there is a sticky dedicated to resources (where you can find suppliers for just about anything for a kart).
Connecticut, USA
The HF tires will not last until x-mas. You'll be lucky if they last until labor day... as in like half a week...:lolgoku:
About the tires from eBay: I don't have a clue, so wait for the other's to come around... but I would buy from a big name, not a no-name. A brand like Carlisle or something.
Poboy kartman
Senior Moments Member
White Settlement Texas
thanks. I'll find the tires. But i guess the question is can i switch the front 4inch tires to be the same 6inch tires on all 4?
also i found this on ebay:
http://www.ebay.com/itm/2-Go-kart-ATV-tire-and-wheel-assembly-145-70-6-kd14576fla-/331001709454
SAY WHAT? ?,,,,,, JK....YES.....You can find tires all day long with the same OD and 2" diff in ID........BUT. ...... WHY?????????? Would you want to equalize your tires when you have different sized rims? ??????
Usually. ...the only REAL...advantage is being able to rotate the tires. ....JMHO........But I think it's a waste of time and money. .....
I agree with fabro man. If you want to do that you need to line them up spot on. As if the thread continuse through.
I'm sorry, i meant add another nut so that i can hook up a spring to it. Not to change where the rod screws into. There are two holes on the rod. One has the screw threw it the other would be a spot for a spring. I was thinking of adding a nut to the frame so i could add the return spring.
I was referring to the fact that you can't thread the rod through two nuts if there are bends at the ends of the rod...
As for the tires. i agree they might suck and get tore up fast. For now they are better than what was on there till i find tires. He is going to ask for tires for xmas. So if you guys know where a good place for 10 inch tires with 4 inch rims and 15 inch tires with 6 inch rims that would be helpful.
Also should I or do I have to stay with 4inch tires on the front? Or can i go all 4 tires with with 15x6?
Thanks.
It's not just the tyres that are the problem, the wheels in general are lighweight junk; low speed bearings & light gauge material used for the rims...
You can but, you need to keep an eye in the height of the front vs the rear of the kart; you don't want the front to sit higher...
MikL99
Ohio
Thanks for the update. The rod for the breaks is a straight rod that doesn't bend in. I've seen those. This is just a straight bar that has a bolt connected to the break petal and then another straight end that connects to the band break.
As far as the tire. I don't mind staying with the 4 inch tires on the front. Just thought it might be easier to get tires.
I need to go find a store locally because the price of shipping kills any good price i find.
Also an update of my progress. I got the throttle cable hooked up last night. I'm not sure i like how it is setup but it seems to work. Its almost a bit too long but its working. I also got the clutch to put on it. This is going to be the part that i have to work on. I need to get some washers tonight for behind the clutch as there is a lot of slop. I want to say its about a 1/4 of inch of space or slightly higher. I think the washers will work well to fix that.
next comes the chain. I know i can adjust someone to make the chain tighter but the new Engine and clutch might be hanging a bit lower than the old one. So i don't know if you can take links out of the chain or order a smaller one. We shall see.
Post a pic & we'll see what's happening; we may be able to suggest another way...
Of course you can... with the correct tools...
At the very least, you need a hammer, a punch & a master link; if you prefer to go pro, spend the big bucks on a chainbreaker...
MikL99
Ohio
I'll post some pics soon. I'm going to work on the throttle more. Its fun to mess with so i'm ok fulling around with it.
I'll mess with the chain this weekend. I got the clutch all setup correctly with a washer behind it. Seems good.
Thanks for all the advice guys. Everything is coming along well. As for the tires. I was looking over the rims last night and they look OK. I didn't see any bends on the rims on the back tires so i think i'm just going to order the Tires and not the wheels. This should reduce the cost in half. I have some local stores around here that i can visit and i believe they run around 25 bucks a tire. Not bad. Although i don't think i want to replace the tires till later after he breaks it in for a bit.
After searching just tires i found these on amazon:
http://www.amazon.com/Kenda-Scorpio...qid=1409233496&sr=1-5&keywords=145/70-6+tires
I read reviews from other sites and these seem to be a good brand. 22 bucks with free shipping and no tax might be the best value.
Connecticut, USA
I also just bought a HF chain breaker...NEVER AGAIN.
It's awful and doesn't work very well at all. I think the peg that pushes out the link is to big... I don't know I gave up for the night. It's the last piece of the puzzle to get my go kart working, but I lost my patience and said it's dark out, so I can't ride it now anyways...might as well wait until the morning.:lolgoku:
You think i would stop buying things at HF now, but NOPE. :lolgoku:
Harbor Freight; Good stuff; Once
That's what my Family pretend's their motto is, because everything they make is only good one time... but it's 1/16th the price of a normal tool... soooooo...
Edit: Just for the record, i was a little angry at the time lol. The HF chain breaker gets the job done! Not well... But it does...
firemanjim
Just kartin' around....
Houston Texas
:funnypost:
I definitely agree..... Bought a 90* fixture clamp to build a kart, a few years back. I made ONE perfect 90* joint...... The rest where off by 5-15*...
O, that's that's POCrap right there in the pic....... :censored:
MikL99
Ohio
lol. So instead of taking a link out of the chain i added 4 washers to the motor plate. Hooked everything back up and the chain seemed good. Not too tight but not loose.
I also hooked up the throttle cable correctly this time. I didn't even have to add any return springs.
Started it up. And Success! I have working Kart. My son got to try it out at 11pm last night. He was very happy.
So for now he is going to drive it around.
Next fixes are new tires and a new Paint Job. I don't think i've put too much into so far.
Go kart - 125.00
Engine - 85.00
Clutch - 25
Throttle Cable -15
Total = 250.00 for a working Go-Kart.
Connecticut, USA
I tried my go kart out at 10:30 last night.
Cheers on having neighbors that hate us.:cheers2:
No, I was only out there for 3 minutes, and a neighbor came over. He was like 25yo and was like "Sweet go kart!!!".
MikL99
Ohio
So do you guys know where i can get parts for this Manco? I wanted to look at replacing the front right and left spindles on it.
I found these and i think they are the same as the one's i need. They just changed the part number.
https://www.gopowersports.com/product_p/2457-2z-2457-2458.htm
Lol never mind. Over 60 dollars just isn't worth it. I think i'll take them apart and try to clean them and paint them.
